Old 02-04-2006, 06:53 PM
SonBeem7V  is offline
Posts: 29  -  iTrader: (0)
Smile
MODE 4 vs TRIPLE RECTIFIER,,,,,,,,
hey ppl
im scrapping my combo an getting a head an cab,ive spent nearly 2 mths looking up reviews etc to find the best one for the sound i want,and have narrowed it down to the Mode4 & Triple Rectifier,but would like the opinion of some one who has maybe used one or both of these amps to help me make up my mind,
Mercy Bucketz,,,,
Old 02-04-2006, 07:13 PM
Nordhauser  is offline
Posts: 970  -  iTrader: (2)
Re: MODE 4 vs TRIPLE RECTIFIER,,,,,,,,
Originally Posted by SonBeem7V
hey ppl
Mercy Bucketz,,,,
To be honest, I wouldn't recommend either. I would take a JCM over a Mode 4 and a Mark over a Triple Rec. Go to a local guitar shop and play them. It really is based on your opinion, not ours. Not to mention Marshall has a somewhat different sound than Mesa.
Old 02-04-2006, 07:31 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
I'm with Nord, neither.
I had a Triple Recto, it was a decent amp, but I'm grew sick of the Recto sound, plus at 150 watts it pointlessly loud, as for the mode 4, it's solid state so I wouldn't reccomend it for that reason alone.
Old 02-04-2006, 07:41 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
My experience with the Mode 4 is that it sounds like crap. I'm not a big fan of Rectos either, but if you like them, the Triple is pointless, the Dual will do everything you need, even a Single will be loud enough but doesn't have all the features that the Dual and Triple do.
Roger
Old 02-04-2006, 07:42 PM
Ant1981  is offline
Posts: 2,181  -  iTrader: (3)
The mode four isn't solid state, it's hybrid. It has an all valve pre amp with transistor poweramp.
Old 02-04-2006, 07:52 PM
elcid  is offline
Hybrid, solid state, who cares, tone comes from overdriving POWER amp tubes, no power amp tubes, it may as well be solid state.
Old 02-04-2006, 08:17 PM
Ant1981  is offline
The gain, overdrive comes from the preamp actually, but of course an all valve amp sounds better. And to say who cares? Well you obviously do, and I certainly do, and so does everyone else who is playing guitar and wants a great sound.
Old 02-04-2006, 08:21 PM
elcid  is offline
I stand by my who cares, I find Hybrid to be little more than a marketing gimmick and it is no better than solid state. That's my story and I'm sticking to it.
Old 02-04-2006, 08:58 PM
i once tried a mode 4 at the NEC guitar show and wasnt that impressed,i wished i could of plugged a jem in to get a better idea as i play nothing but a 7v,the sound i want is a mark tremonti type distortion (with creed) very heavy that can handle a bit of tuning down ive heard amp start to lose the bottom end when you tune down and play heavy,,,
Old 02-04-2006, 09:06 PM
megadeth  is offline
Posts: 1,221  -  iTrader: (10)
as others have mentioned...
MODE 4 sucks because it is solid state.
Triple Recto is WAY TOO loud !!
if you are seeking nice MARSHALL tone then get a JCM800 2203.
if you are a metal maniac then I would suggest a triaxis. It has mark IV AND a recto mode. Also, If you use it with 2:90 poweramp then tonal possibilities are infinite.
Old 02-04-2006, 09:08 PM
megadeth  is offline
this is a clip off my triaxis in MESA MARK IV mode (LD2 green). I used SD-1 for a little tone shaping.
http://s61.yousendit.com/d.aspx?id=0...90Y9C7TMDGSK5X
Old 02-04-2006, 09:16 PM
up till now ive allways had combos but now need more volume an more bottom end,ive allways used a pod mk2 when i get a head an cab should i not use the pod an plug direct into the head,will the pod spoil the sound..
Old 02-04-2006, 09:19 PM
megadeath
is that you actually playing or just a sample,,
Old 02-04-2006, 11:40 PM
megadeth  is offline
that is me playing.
Old 02-05-2006, 12:26 AM
megadeth  is offline
i use marshall 1960 BV for more bottom end and my triaxis delivers enough of it too. if you use 9/8 gauge then i'd suggest you to switch to 10/11 for more meat in the tone.
FS: Mesa Triple Rectifier, Mesa Cab BUCK Classified Ads: Guitars and Gear 7 01-25-2009 02:41 PM
FS:3 Channel Mesa Triple Rectifier corgan33 Classified Ads: Guitars and Gear 4 12-13-2005 12:40 PM
WTB- 3 channel Mesa Triple Rectifier IbanezPrestigeBoy Classified Ads: Guitars and Gear 0 11-08-2005 05:47 PM
Mesa Boogie Rectifier CyBerAliEn Gear and Equipment 1 04-25-2005 05:07 PM
Lesson 6: *a' la Mode - Lydian, Mixolydian, Dorian, Aeolian, jem7vwh Guitar Lessons & Music Theory 29 03-01-2005 01:16 PM
