Old 10-09-2003, 12:08 AM
the second eye  is offline
Posts: 87  -  iTrader: (0)
my ada doesn't work
the other day when i came home from practice, i went to plug my ada mp1 back in and set it up but when i switched it on nothing happened, the od1 led blinks every time i flip the swithch and the tubes glow, there is also a humming noise, does anyone no how to fix it please help!!
Old 10-09-2003, 03:59 PM
Tubarão Guitars  is offline
Posts: 3,965  -  iTrader: (0)
Images: 3
Fried Valves...
Tubarão
Old 10-09-2003, 04:32 PM
bammbamm  is offline
http://www.adadepot.com
They have schematics.
I would try the tubes 1st.
From there I don't know how much you know about electronics troubleshooting.
Bamm
Old 10-09-2003, 07:46 PM
would the tubes light up if they were fried
Old 10-13-2003, 03:28 PM
jemke  is offline
Posts: 318  -  iTrader: (0)
The ada is self diagnostic. If there is a software problem a number between 1 and 4 will light up at the display and you could find the problem.
So if it starts up normal and has no number lighting up, it is probably the valve.
Old 10-13-2003, 08:41 PM
ok then , ithink i will take to a adio electrican to get it fixed
