Gear and Equipment
My Mesa 50/50 has arrived, but...
Gear and Equipment
07-21-2007, 12:47 PM
LightSeeker
Posts: 36 - iTrader: (
It arrived today, after many complications (like getting through customs and charging me 150€, those goddamn bastards ) but it's here.
Played it through my local store's Ibeanez 4*12 cab. The cleans sounded grerat! will post clips soon (probably tomorrow), but the distortion was very harsh, when plugged through the normal output. It changed when I connected the
power amp
to the recording output of my
Mesa Studio preamp
. I got a much more smoother, santana like distortion. But plugged into the normal output, it just sounded bad. What is wrong here? How can I get this kind of a sound on the normal output (because through the rec output the volume drops significantly and the cleans aren't so good)
It was the same before, when I was running my studio through my Vox AD60vt amp's efects loop, but then I thought that the cause of the problem was the lousy power amp section. Now I see, that the problem is the pMesa Studio preamp, but I don't know what is actually wrong with it. This thing is supposed to be on the level, yet when switched to distortion and ran through a power amp on the main output it really sounds the same as my Vox AD60vt modelling amp.
What should I do' Any idea of what might be wrong?
LightSeeker
Find all posts by LightSeeker
07-21-2007, 03:10 PM
Lefty Robb
Posts: 4,930 - iTrader: (
Re: My Mesa 50/50 has arrived, but...
Change the tubes...
Lefty Robb
Find all posts by Lefty Robb
07-21-2007, 04:25 PM
LightSeeker
you think that they are the problem? It is true, that they have been in there for two years, but I've heard that preamp tubes last a looong time
LightSeeker
07-21-2007, 06:47 PM
Lefty Robb
The first thing I do anytime I have a bad output on anything with tubes is change em, because you know if you change em and it sounds exactly the same, its time for it to go to the amp doctor.
Lefty Robb
07-21-2007, 09:25 PM
Martyr Machine
Posts: 340 - iTrader: (
LightSeeker
They can last a long time, or they can die quickly for no reason at all. It's just what they do.
Martyr Machine
Find all posts by Martyr Machine
07-22-2007, 05:49 AM
LightSeeker
Bu isn't tube failure suppose to go in hand wit loss of high end and output and so on. I exerience neither of those. Just the harsh, solid state like distortion tha Mesa isn't known for
LightSeeker
07-22-2007, 07:58 AM
LightSeeker
Test of the rig
lo-fi URL:
http://www.soundclick.com/util/getpl...d=5582011&q=lo
hi-fi URL:
http://www.soundclick.com/util/getpl...d=5582011&q=hi
al done in one take, the parts are separated ba an annoying noise. The sequence is as follows: 1. clean (slightly distorted) sound from the nomral output of the preamp into the
power amps
, 2. clean (slightly distorted) from the recording output, 3. Overdrive channel from the normal output and 4. overdrive from the recording output.
I', really dissapointed. It's not smooth at all. What the hell is wrong?
LightSeeker
07-22-2007, 12:47 PM
shogun
Posts: 1,525 - iTrader: (
link does not work
shogun
Visit shogun's homepage!
Find all posts by shogun
07-22-2007, 12:53 PM
LightSeeker
Test of the rig
lo-fi URL:
hi-fi URL:
Sorry, maybe something was copied wrongly. Here's the link again (it works in my browser)
LightSeeker
07-23-2007, 04:00 PM
LightSeeker
I went to an amp tech today, he tried it out and said he loved the sound of it. "It's the thing that cuts through the live band. That's how Mesa is supposed to sound like. it's supposed to have a nasty sound. If you wanted a smooth distortion you should've picked up a marshall, which sounds fine by itslef, but gets lost completely with a live band," is what he said to me.
Fully functional or not, I still dont like that kind of distortion. It just sounds fizzy and harsh to me, and if I put the preamp through the recording output the cleans get muddy and even then the overdrive isn't as good as I wanted it to be.
I always thought that Mesa is known for their smooth santana like tones (except the rectos of course
) and the sound coming from my preamp is definetely NOT that kind of sound.
"If you want to get that kind of a sound get a Triaxis," he said to me.
Is he right? Wha kind of a premap would give me those nice tones that I'm looking for?
LightSeeker
07-23-2007, 07:05 PM
shogun
i wouldnt agree that santana has a smooth tone, at least not live.. IMO recto's are the ****s for lead ( on their own ).. p.s. a
tube amp
does not sound good at a low volume or even on its own loud... u have to be in a good room / be with a band to appreciate them.. ( talking about high gain
tube amps
what did u mic this with
shogun
07-23-2007, 09:14 PM
LightSeeker
I miced it with an AKG 100 perception microphone.
I did play it at 15 watts almost fully opened up, it didn't sound any better actually.
LightSeeker
mesa studio preamp
power amp
power amps
preamp tube
tube amp
tube amps
how much is mesa mark iv worth?
mesa boogie are over rated
how to dial out fizz in mesa mark iii
compare mesa boogie single dual recto
how to dial in Mesa mark iii
UCEWFM and 520,560 body's for sale MESA 50/50 power amp
standing8count
02:58 AM
Mesa 20/20 or 50/50 or 2:90 - The big decision
bduersch
Gear and Equipment
05:03 AM
Putting tubes in my mesa 50/50 - My brain has seriously lost
MorbidAngel
Gear and Equipment
05:53 PM
Cabinets and the Mesa 50/50 - I think I'm a massive tool...
MorbidAngel
Gear and Equipment
04:12 PM
05:03 PM
