Gear and Equipment
Need advice - rack mount amps -normal amps ?
Gear and Equipment
12-03-2006, 04:38 PM
Jaden
Posts: 2,464 - iTrader: (
OK so... I need a new amp but ive been through the "usual suspects" list of amps - sometimes twice
question is, ive never tried rackmount gear, so whats the pro's and con's of going rackmount with everything ?
I have £600 - 700 to spend !
ALL advice welcome - even if its "just buy xxxxxx you bloody idiot !"
I would have £1000 but I need to satisfy my S470 GAS
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
10-15-2008, 12:26 PM
bammbamm
Posts: 4,134 - iTrader: (
Re: Need advice - rack mount amps -normal amps ?
It depends on what you want to do.
I personally think the best bang for the buck currently is a modded ADA MP1 paired with a good power amp like a Mesa 20, 50, 90, or 100 watter.
The benefits are you can lug your whole rig around in one case, mostly connected, just plug in your speaker cab, guitar and midi controller and off you go.
The other benefit is that you can preset your tones, and recall them with the touch of a button. Granted, there is some setup time involved, but in the grand scheme of things, it's negligible.
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
10-17-2008, 01:46 AM
Ekim
Posts: 1,486 - iTrader: (
Reviews: 4
I need some sort of guitar preamp. I'm looking at the Peavey Rockmasters and the ADAs.
If I had a lot more dough, I'd be looking at the Randall modular stuff.
Ekim
Find all posts by Ekim
10-17-2008, 03:57 AM
Lefty Robb
Posts: 4,930 - iTrader: (
There are so many advantages to going all rack. When I try to explain to friends and what not about my gear they kind of look cross eyed at me because all they know are your everyday amps, and here's what I tell them:
When you buy a house, you have two options, buy one that is already build or build one yourself. Building a house, like going all rack, is usually the more expensive option, but it lets you design something from the ground up to suit your tastes and needs, and not what someone else thought was good enough for them. Going all rack allows you to truly design a sound that you want. Allowing you to build every step of your sound, from preamp, to affects to amp, and everything in between, something you can't do with just a single amp head. For example you could choose a Carvin preamp (quad-X) and a VHT power amp (like a 2502), or a Mesa preamp and a Marshall power amp, you could have a solid state preamp and a tube amp, or a tube pre amp and a solid state power amp, so many different things to choose from!!. Going rack really lets you experiment with all kinds of tones never thought of before. Racks are truly a tone chasers and tweakers dream. going from regular amps to racks is like going from Duplo's to Lego Technic! This is why I love racks and can never go back to just playing on regular amps. Here are some examples of why I love them:
1: A lot of Power amps have the flexibility to try different types of tubes.(Simul-Class FTW!)
2. You can use different pre-amps without changing your power amp and vise versa.
3. They tend to sound better at lower volume.
4. Save your settings! no more trying to remember where all the knobs were set.
5. Two words: Midi Switching!
6. Cheaper to replace 1 unit then everything if something goes.
04:03 AM
Lefty Robb
Find all posts by Lefty Robb
10-20-2008, 05:41 AM
bammbamm
I actually didn't get a gig with a band because they didn't like the "Rack Sound"?!?!?
Some people flip when you rack mount something. Funny thing was, my tone was way better than that other guitarist, he was just using a Marshall with a bunch of pedals. Flippin moron.
bammbamm
10-20-2008, 06:08 AM
Morbid
Posts: 116 - iTrader: (
All of my stuff is rackmount, and I wouldn't change a thing about it.
Well, except my ability to afford more cool toys!
The only disadvantage to rackmounting everything for ME is that it's heavy, but the advantages far outweigh the disadvantages.
I've got a Mesa Boogie Mark IV, GCX Control System, Rocktron Xpression, Furman Power Conditioner and some pedals in my rack case. As a result, no matter what, I'm always wired and ready to go. Even if I relocate and go to a gig, I only have to plug in a few cables and I'm done.
All in all, it's easier, too. What can I say...I'm happy
Morbid
Find all posts by Morbid
10-20-2008, 06:52 AM
kotornut
Posts: 1,847 - iTrader: (
bammbamm
That dude must've had a huge hard on for your gear and was jealous.
kotornut
Visit kotornut's homepage!
Find all posts by kotornut
10-20-2008, 08:40 AM
Matheau
Posts: 206 - iTrader: (
The advantage of a rack is that you can customize everything, and even potentially get all of your effects and other pieces as one piece of gear.
The disadvantages are weight and size are usually going to be substantially more than a head or a combo. Also the cost is usually going to end up being significantly more and there is a more limited amount of actual equipment options. Just look at how many different heads Marshall or Engl or Mesa have, then see how many pre-amps and power amps.
Matheau
Find all posts by Matheau
how to turn on tube amps
low e string causes b string vibrate normal?
how to direct mount emg 707 pickups
guitar ringing noise normal?
amps what is the brown sound
The Jemsite guide to amps
Mr Orange
Gear and Equipment
117
12-14-2011
08:05 AM
Rack Mount Power
Ant1981
Gear and Equipment
07:18 PM
Simple rack setup- Any advice appreiciated
Swirly
Gear and Equipment
35
03-15-2004
12:37 PM
Combo Amps Advice - Line 6 , JM60, etc.
dwalsh5150
Gear and Equipment
08:41 AM
Rack power amps vs Heads
sebastian
Gear and Equipment
01:06 PM
02:44 AM
