Old 01-25-2001, 05:39 PM
ultrazoneman  is offline
Posts: 25  -  iTrader: (0)
need help in amps - please help me choose
hi i have a jem77fp but the problem is that i have an stupid epiphonestudio10 amp
so i want to purchase a better amp
and someone is selling (here in mexico) amps
so my choices are:
marshall jcm900 4501 50+50 w (used)in: 450
crate gx212 (used) in: 350
and line 6 spider50w (new) in: 400
so which amp do i buy which is the best
are the prices expensive or they are ok
please help me if the marshall its in a good price or its expensive
i play a lot metal but i also like clean sound and also distortion
help please
Old 01-25-2001, 06:05 PM
tomizm  is offline
Posts: 417  -  iTrader: (1)
need help in amps
Personally, I think solid state Crates are only good for tuning (using the clean channel) *Other than that, it would be an insult to your guitar to play it thru that.
I wont elbaorate any further because that's not what this discussion is about.
I would go for either the Line 6 or the Marshall.
Old 01-25-2001, 06:21 PM
pri0531  is offline
Posts: 622  -  iTrader: (0)
need help in amps
In order to make the right decission play the line 6 dry (no effects) and then go play the marshall (also dry). *The one that sounds best to you at that point is the one to go with. *That sound will be your base sound / tone. *Any effect that you add will just be icing on the cake. *
Out,
GP
Old 01-26-2001, 10:43 AM
jeff l  is offline
Posts: 554  -  iTrader: (0)
need help in amps
Yeah I agree with GP,
* * * * * * * *Play both amps 'dry' so that you're not swayed by the effects of the Line 6. I think you'll find the more authentic tones coming from the Marshall and more versatility in the Line 6 amp.
* * * * * * * * * * * If you're planning on cranking your amp to 11 then I think you'll be happier with the Marshall. Just keep in mind that I'm a total Marshall geek/freak and an utter tube-snob so I'm slightly biased (pun intended).
Old 01-27-2001, 01:27 PM
need help in amps
hey and how about the marshallg80rcd
its :380 (new)
it has 80w ,footswich, and i read in harmony central that is a good amp
Old 01-27-2001, 09:24 PM
jeff l  is offline
need help in amps
Don't waste your time with a solid-state Marshall.
Old 01-27-2001, 10:06 PM
bob oakman  is offline
Posts: 922  -  iTrader: (0)
need help in amps
I used to have a fair amount to say on this subject. Then I finally realized that what I like for tone and gain is unlike what most prefer, so my perspective is out in space somewhere and probably won't help.
However, I agree that comparing different rigs side by side is the best way to find what you personally like. My ears get, how should I say, "jaded" to tone if I listen to one amp long enough. Then I plug into a different one and find that perhaps the first one wasn't all that great after all.
I guess I still do have a fair amount to say about it after all.
Old 01-31-2001, 12:36 PM
goldboy  is offline
Posts: 170  -  iTrader: (0)
need help in amps
Personalmente,
yo creo que el Marshall amplificador tiene el poder y el sonido que tu quieres. los tonos de el marshall puede ser bien diversificado. nota los sonidos y tonos de Satriani de su carrera antes de Time Machine..y realmente eso es lo que el usa en el studio y especialmente en tour en su equipo.
saludes.
Old 01-31-2001, 09:19 PM
Doink  is offline
Posts: 428  -  iTrader: (8)
need help in amps
¿Yo quero Taco Bell?
Old 01-31-2001, 10:16 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
need help in amps
Drop the chalupa!
I would play the Line 6 and the Marshall side by side first. * If you don't want to spend extra $$$ on outboard gear but like effects, the line 6 is the way to go. *I don't really like Marshall but I really don't like Crate. *If you want a bit more power and possibly a more versatile setup, save some more money and get the Marshall and a Line 6 pod.
My opinion on the Line 6 stuff is this. *It's great stuff for what it is. *You get ton's of effects and they all sound good. *I feel they sound about 80% - 90% accurate. *That's really good for any amp that has that many options. *To get 100% sound of something you will only get it by building that same setup. *For versatility in a single package I don't think you'll beat the Line 6 for the money.
On another amp choice, recently at Axe music, I was waiting for a sales dude and I got kind of bored so I picked up a DBK that was on the wall and went into the amp room. *No-one was in there so I found an amp that was plugged in and started to play. *Well, this amp sounded great for a little amp! *It was the new Peavey Bandit 112 and it was the best sounding Peavey amp I've ever heard. *Quite versatile for an amp without a processor too. *The best part was it was only $550 Canadian brand new! (about $360US). *I thought maybe the pickups in the DBK had something to do with it so I also tried a ESP (LTD), a Parker Fly deluxe, an American Strat, a PRS McCarty model, an RG550, and a couple cheapo wanna-be Ibanez's called "Phil" guitars. *They all sounded great through it. *I'm not a Peavey fan but this amp is starting to change my views a little bit. *Maybe this one was a freak too but I damn near bought it for a little practice amp.
Good luck finding the new amp!
Jeremy
Old 02-01-2001, 07:48 PM
Pablo  is offline
Posts: 633  -  iTrader: (1)
need help in amps
If the line 6 spider has the rectified, modern hi-gain and POD layer models I'd go for that.
Guitar techniques tabbed Die to live and added the settings for the sound *which they done on a POD. Very close. And previously I thought the soldano settings were crap.
Plus you get your marshall sounds too.
I vote for the line 6 but you would need to play it and see if you dig it.
guitar tech, marshall amp, parker fly, parker fly deluxe, peavey amp, peavey bandit, practice amp, prs mccarty
