Old 08-04-2005, 09:15 PM
shane peoples  is offline
Posts: 10  -  iTrader: (0)
Noise Gate
I have a legacy that I play at church, there are florescent lights in the building which makes the amp noise. I also have a compressor with a noise gate, I was thinking of using it to cut down on the noise. Where is the best place to put the noise gate in the signal chain? I was thinking in the effects loop, if so will it hurt the amp? Thanks.
Old 08-04-2005, 09:47 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
Re: Noise Gate
No, it won't hurt the amp to put it in the effects loop, that's the best place for a noise gate. I wouldn't use too much compression, if any, in the loop though.
Old 08-04-2005, 10:12 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Noise Gate
If the noise is from the amp, the effects loop would be a good place to put the noise gate.
I seem to have found two schools of thought about noise gate placement: 1) Place it first, before anything else. This cuts the noise on the signal from the guitar before it hits any other effects or amplification. 2) Place it in the effects loop to cut any noise created and amplified through the effects and preamp. The problem with this is that any earlier effects have already been applied to the noise as well.
I am currently using a Boss pedal, which I find quite effective at cutting the noise (particularly from the noisy Strat single coils) and convenient (with a foot switchable mute, useful when switching guitars). It has two sets of inputs/outputs and (as recommended by Boss) can be wired first in the input chain, and also has a section for the effects loop -- with the idea of operating at both points. Seems like a good solution -- just have both. Right now I am not using a lot of effects and haven't found a lot of difference with the effects loop part, so I am running it right now only as the first thing in the chain. That seems to work well (for guitar noise more than amp noise of course).
Old 08-04-2005, 10:34 PM
Gex  is offline
Posts: 962  -  iTrader: (1)
Re: Noise Gate
Actually, I think a power conditioner would be more effective. I forget what theyre called, but they have line filters that they sell at Radio Shack and other places that is supposed to block interference from the power lines.
boss pedal, foot switch
Noise Gate and compression - Influence in Guitar God's tone Mirrored CAT Gear and Equipment 27 12-17-2010 05:16 PM
WTB: Good Noise Gate nick1 Classified Ads: Guitars and Gear 4 06-18-2005 01:54 PM
noise gate shane peoples Gear and Equipment 1 06-07-2005 05:01 PM
Noise gate for rack: need high quality, reasonable priced SilverSurfer2 Gear and Equipment 3 01-09-2004 03:28 PM
Noise gate on an ADA MP-1? leishan Gear and Equipment 11 01-13-2003 08:52 AM
