Old 12-16-2008, 05:54 PM
Devon8822  is offline
Posts: 389  -  iTrader: (3)
Noise Suppressor
What are the best noise suppressor available? Is a noise suppressor the same thing as a noise gate?
Old 12-16-2008, 06:23 PM
Jacob K  is offline
Posts: 183  -  iTrader: (0)
Re: Noise Suppressor
A noise gate is a device which cuts the signal when it goes below a certain amplitude. That is, when you don't play your guitar, the noise gate will make it totally quiet, for example. You can adjust the level at which it kills the signal.
Noise suppressors are devices which attempt to filter out noise from your signal, leaving back the tone. Unfortunatly, it is impossible to figure out what part of a signal that is noise and what part that is tone, so killing the noise will also affect the tone (if only slightly for the best suppressors).
I would suggest spending your money on getting your guitar shielded properly if you have noise problems.
Someone else can probably suggest you something if you wanna go with a pedal
Old 12-17-2008, 01:52 AM
Van Noord  is offline
Posts: 157  -  iTrader: (0)
Reviews: 12
Do you want to gate feedback, or eliminate unwanted amp noise?
I would go with an ISP Decimator.
Old 12-17-2008, 04:23 AM
GLG421  is offline
Posts: 323  -  iTrader: (3)
understanding what you are trying to eliminate will go a long way to a good answer.
FS UK: Modded DS-1 and MT-2 + NS-2 Noise Suppressor axemanrio Classified Ads: Guitars and Gear 4 05-25-2008 10:10 AM
Noise Suppressor? BozTheK Gear and Equipment 1 07-15-2007 03:46 PM
FS: Boss NS-2 Noise Suppressor vaijem777 Classified Ads: Guitars and Gear 0 07-09-2007 06:36 PM
Boss Ns-2 Noise Suppressor JasonMalmsteen Gear and Equipment 22 04-11-2007 04:05 PM
Boss Noise Suppressor NS-2 BluewookieJim Gear and Equipment 4 03-15-2006 07:26 AM
