Old 02-10-2007, 09:39 PM
rya  is offline
Posts: 388  -  iTrader: (0)
OH MY GOD HELP
UGH!!!!! I HAVE A LINE 6 PODXT, AND I DONWLOAD LINE 6 MONKEY, THEN WHEN I DOWNLOAD THE LASTEST DRIVERS, IT SAYS TO PLUG IT IN. I PLUG IN THE CABLE, TURN IT ON, AND IT JUST SAYS USB DEVICE NOT RECOGNIZED! SO I CANT GO THROUGH THE DRIVER PROCESS. I'VE TRYED THIS 8 TIMES AND COUNTING AND VERY VERY FRUSTRATED!!! > WHEN I OPEN UP LINE 6 MONKEY IT STILL SAYS THE DRIVERS AREN'T INSTALLED!! PLEASE HELP!
Old 02-10-2007, 09:41 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
Re: OH MY GOD HELP
SELL IT ON ****!
I'm just kidding, I have no idea of what to tell you to help you, but I'm sure there are plenty of people on here with pods that can help.
Good luck.
Old 02-10-2007, 09:48 PM
nightfiend14  is offline
Posts: 1,005  -  iTrader: (10)
Re: OH MY GOD HELP
trying plugging it in before you start the computer. Sometimes that helps tons, some of my recording stuff, and my Vamp Pro won't work well with my computer unless I have them plugged in before starting the computer, then they work just fine.
Old 02-10-2007, 10:05 PM
wilch  is offline
Posts: 1,783  -  iTrader: (0)
Images: 1
Re: OH MY GOD HELP
Try the line6 forums.
Old 02-10-2007, 10:23 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Re: OH MY GOD HELP
ASK YOUR MOMMY AND DADDY FOR HELP!!!
Old 02-10-2007, 10:54 PM
j.arledge  is offline
Posts: 1,803  -  iTrader: (30)
Re: OH MY GOD HELP
you have to go and actaully install the item on the computer , just like you would if you added a printer or something like that .
something should pop up and ask you about installing the softwear , hit yes and then go with auto-install .
if nothing pops up go to my computer and find the line 6 and then click on it and see if you dont get somthing then .
my guitar port pulled the same crap when i first got it
Old 02-10-2007, 11:22 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Re: OH MY GOD HELP
LMAO
Be nice now
Old 02-10-2007, 11:26 PM
toneboy  is offline
Re: OH MY GOD HELP
Originally Posted by waylay00 View Post
LMAO
Be nice now
I was, hence the smiley. To be blunt, ift the post wasn't so exclamatory, I wouldn't have responded at all. I found it amusing I guess.
Old 02-10-2007, 11:31 PM
Clydefrog  is offline
Posts: 284  -  iTrader: (6)
Re: OH MY GOD HELP
Install the drivers by themselves. Once that is done, go into your hardware profile, select the PodXT (usually at that point, since it still doesn't have drivers attatched, it will have the yellow ! mark). Then double click it, select "Install Driver" or something to that effect, and point it to the direction of the Line6 install, where you will find a driver folder.
Old 02-11-2007, 01:12 AM
Tubarão Guitars  is offline
Posts: 3,965  -  iTrader: (0)
Images: 3
Re: OH MY GOD HELP
buy BOSS pedals.
and dont SCREEEEEAAAAAMMMMM!!!!
Old 02-11-2007, 02:37 PM
rlintz  is offline
Posts: 466  -  iTrader: (1)
Re: OH MY GOD HELP
+1 for checking out the POD forums at http://www.line6.com/support/forum.jspa?forumID=3. Lots of knowledgeable people there. Also, hit their support knowledgebase at http://line6.com/support/index.jspa and search / browse for your problem.
Old 03-05-2007, 02:42 AM
joeydego  is offline
Posts: 100  -  iTrader: (0)
Re: OH MY GOD HELP
re install the drivers and look on the site for updates.
Old 03-05-2007, 03:15 AM
TongueShredder  is offline
Posts: 1,705  -  iTrader: (0)
Re: OH MY GOD HELP
Originally Posted by Tubarão Guitars View Post
buy BOSS pedals.
+2. Boss pedals are the way to go. I always feel the analog devices sound so much better than the digital ones...
Old 03-05-2007, 05:02 PM
prestigeaxes  is offline
Posts: 185  -  iTrader: (2)
Re: OH MY GOD HELP
alright download the drivers and then plug in the PODXT then it will say unrecognized then you need to select "find software from computer or something" let it search then it will say this may blah blah blah your computer,
click continue then it will set up a system reset point then after that it will work.
Old 03-05-2007, 05:44 PM
al.  is offline
Posts: 152  -  iTrader: (0)
Re: OH MY GOD HELP
calm down man
line 6 forums... they're helpfull enough... Line 6 monkey and line 6 edit.. sometimes u gota locate the drivers manually... dont wory about it
boss pedal, boss pedals, guitar port
