Old 06-14-2002, 11:20 PM
oooo  is offline
Posts: 338  -  iTrader: (0)
original Ground Control users (not the pro) question
Can you do tap tempo ("CC") functions with the original ground control? Also, I've read that the expression pedal input can only be used with certain pedals... will the Ernie Ball Volume work?
Old 06-17-2002, 12:23 AM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
You can do tap tempo...I use a Boss FS-5U for this into one of the exp inputs. The EB pedal works great as an exp pedal...I had less satisfactory resultts with a Boss volume pedal.
(units controlled" Rocktron Piranha &amp; Replifex)
Greg
ernie ball, expression pedal, rocktron piranha, volume pedal
