Old 03-07-2008, 07:38 AM
vejiita  is offline
Posts: 56  -  iTrader: (0)
Overdrive pedal for boosting solid state/digital amps?
can anybody recommend any booster/overdrive pedal that i can use to to boost solid state/digital amps to make the sound fatter/thicker without any loss of low end?
thanks
Old 03-07-2008, 10:30 AM
rty13ibz98  is offline
Re: Overdrive pedal for boosting solid state/digital amps?
the fulltone fulldrive.
rich
Old 03-07-2008, 12:03 PM
shogun  is offline
Posts: 1,525  -  iTrader: (13)
http://www.jemsite.com/forums/showthread.php?t=74529
Old 03-07-2008, 03:27 PM
microdmitry  is offline
Posts: 1,687  -  iTrader: (4)
Modeling amps should not be boosted. You will just overload their ADCs which will not have the same effect as with tubes. They simply cut the signal down to levels they can digitize.
Old 03-08-2008, 12:05 AM
TheMusicBucket  is offline
Posts: 143  -  iTrader: (0)
-Should- not be boosted?
I'm sure I'm not the only one who has gotten good results using pedals through my SS amp.
Good as tubes? No.
Old 03-08-2008, 01:06 AM
Lefty Robb  is offline
That is SO not true. I've ran many pedals in front of modeling units and it sounds great, the best was a TS-808 very clear and articulate with no color.. Granted your going to get a better result from tubes, but still, it ads life and character to digital units.
Old 03-08-2008, 03:07 AM
Good as tubes? No.
Notice I said _modeling_ amps should not be boosted. SS and modeling amps are different.
Old 03-08-2008, 03:10 AM
TS-808 is not a boost. It's an overdrive. Overdrive compresses the input signal, so if you don't crank the Level knob too high (i.e. if you don't actually boost), you're only making digital conversion easier, adding some harmonics and mids.
Old 03-08-2008, 03:21 AM
Duh, but I think he's using boost as a loose term.
All he wants to do is improve his tone, not increase volume, which I think your considering as a "boost" perhaps? TS-808 does this. But what I think he's looking for is BBE after the preamp not a pedal in front of the preamp, at least the goal of "make the sound fatter/thicker without any loss of low end" would be reached.
Old 03-08-2008, 10:40 AM
Mr.WizardNeck  is offline
Posts: 917  -  iTrader: (0)
I use a tube mic pre before my modeler and it makes it sounds loads better.
overdrive pedal
The Jemsite guide to amps Mr Orange Gear and Equipment 117 12-14-2011 08:05 AM
Guitar Amps bonehead189 Gear and Equipment 55 09-25-2005 06:28 PM
Pickups and solid state amps Fry Pickups & wiring 8 02-03-2004 02:51 PM
TUBE Vs. Solid State Amps!? DrPuls Gear and Equipment 23 10-28-2002 04:42 AM
I need Solid State help - A solid state man in a tube world jem7pbk Tech: Setup, Repairs and Mods 5 07-27-2001 12:43 AM
