Gear and Equipment
Peavey JSX COMBO
Gear and Equipment
04-23-2009, 02:52 PM
jrpalomo
Posts: 57 - iTrader: (
Peavey JSX COMBO
hi guys, i was thinking of getting a
jsx
combo
for bedroom/gig use. is it a nice amp? i hope it sounds good at low volume for bedrrom. is the crunch and ultra channel any good? noisy? how about the speaker or tubes? do they suck? should i change em if i buy the amp? any info would be good. im currently deciding between this and a marshall vintage modern combo. i plan on using a jemini distortion overdrive pedal with the amps.i play blues, vaiish gilbert stuff and metal. i also have never tried the amps and cant.thanks.
03:25 PM
jrpalomo
Find all posts by jrpalomo
05-02-2009, 06:18 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Peavey JSX COMBO
You can't go wrong with a JSX combo. The amp will give you a sweet tone right out of the box.
Jimmy
jb4674
Find all posts by jb4674
05-12-2009, 01:22 PM
timerunsout
Posts: 21 - iTrader: (
I've heard it's really versatile. From the demos that I've watched, it doesn't seem to be too noisy...and it does have a master volume right? I think it would be alright for bedroom playing, probably won't sound it's best at low levels though
timerunsout
Find all posts by timerunsout
05-12-2009, 01:26 PM
jb4674
Reviews: 6
Actually, the amp sounds good at low volumes. Obviously, if you need tube saturation you will need to turn it up loud. For bedroom and house playing, you can turn it to 1or 2 and it sounds fine.
Jimmy
jb4674
05-12-2009, 01:56 PM
Derrick M
Posts: 23 - iTrader: (
The JSX is the best sounding combo I have ever had. It sounds great at bedroom levels because each channel has it's own volume, which you can crank, and then use the master volume to turn it down. You won't even need those pedals, this thing sounds great by itself. The crunch channel is "Marshally" and the ultra is high
gain
. It also has a built in noise gate knob, and a 50/100 watt switch on the back of the amp. You can't go wrong with the JSX.
Derrick M
Find all posts by Derrick M
05-12-2009, 08:41 PM
Darin
Posts: 2,459 - iTrader: (
JSX. Love mine at all levels.
youtube.com/mrdarinwarren
Darin
Visit Darin's homepage!
Find all posts by Darin
05-12-2009, 09:20 PM
teokiatuan
Posts: 425 - iTrader: (
wow im tempted to get a jsx now,looked on the bay, good prices too
now to factor in shipping...
can someone give me the dimensions of the head/combo? as well as the weight?
greatly appreciated.
teokiatuan
Find all posts by teokiatuan
05-13-2009, 01:02 PM
timerunsout
jb4674
Jimmy
Proves what I know
Combo:
26.625" W x 20.25" H x 11.375" D
83.9lbs
Head:
26.5" W x 10.875" H x 11" D
54.3lbs
EDIT: Just found a JSX Combo on **** for $1,600. They retail for nearly $4000 here >.<
And it's a local sale too!
01:07 PM
. Reason: .
timerunsout
05-13-2009, 04:03 PM
OLIE_ROCKS_THE_80'S
Posts: 2,770 - iTrader: (
Reviews: 10
JSX are great amps I own a half stack and a combo and I would not play through anything else!!!
OLIE_ROCKS_THE_80'S
Find all posts by OLIE_ROCKS_THE_80'S
05-13-2009, 05:34 PM
Darin
timerunsout
Proves what I know
Combo:
83.9lbs
Head:
54.3lbs
Woah! You don't have your location listed. I suspect it's not the USA.
Darin
05-15-2009, 02:44 AM
Stringz
Posts: 122 - iTrader: (
Am I correct when I say there will be a jsx 1x12 in Sept?
Stringz
Find all posts by Stringz
05-15-2009, 11:28 AM
smooth55
Posts: 1,009 - iTrader: (
Reviews: 59
I've heard whispers of it, though without the dates, but I have yet to see anything concrete on this. Anyone else know?
smooth55
Find all posts by smooth55
05-15-2009, 06:20 PM
jb4674
Reviews: 6
There might be one but, you can probably score one used for about 800 bones, keep searching.
Jimmy
jb4674
05-17-2009, 01:22 PM
ScottB
Posts: 2,208 - iTrader: (
If
Peavey
does the 50w 1x12 JSX, I'm ditching my Rivera R55. I miss the tone of my JSX with the Marshall 1960 4x12, but the bulk was killing me.
ScottB
Visit ScottB's homepage!
Find all posts by ScottB
05-17-2009, 09:25 PM
SilverSurfer2
Posts: 550 - iTrader: (
I'm very happy with mine. Sounds great at any volume, especially turned up in a live band situation. Low volume sounds good too, just wish it had a headphone jack so you can jam without disturbing anyone!
Best combo amp I've played so far, better than the 6100 marshall anni that satch used to play.
The Jsx is very versatile.
SilverSurfer2
Find all posts by SilverSurfer2
combo
gain
joe satriani
jsx
peavey
which better peavey wolfgang musicman axis
is the peavey vandenberg the same at the v-type
peavey xxx what tubes?
who uses Peavey Ecoustic ATS
peavey jsx clean vs carvin legacy?
Peavey XXX 40w EFX Combo
mooro
03:23 PM
FS Peavey XXX 212 combo
7stringofablick
02:10 PM
WTB Peavey JSX 212 Combo
carlos grijalva
07:02 PM
WTB: Peavey 5150 2x12 Combo or head, also XXX 212 combo or head.
Steve-0
12:15 AM
Crate GT212 Combo or Peavey XXL 212 Combo
carlos grijalva
Gear and Equipment
12:04 AM
12:08 AM
