Old 12-28-2007, 07:00 PM
millzy  is offline
Posts: 170  -  iTrader: (0)
peavy valveking 212 problems
i recently just aquired the peavy valvking for xmas...
its great only one problem...whenever i play an A note anywer on the neck
in any region and octave etc etc it makes this loud buzzing noise
its not the guitar
and its pretty annoying..any idea's?
Old 12-28-2007, 07:27 PM
S-man  is offline
Posts: 1,757  -  iTrader: (0)
Re: peavy valveking 212 problems
That's why I didn't buy one...
Check the reverb plate in the back of the amp ...it's loose...most likely.
Though that may not be the problem...ultimately.
Old 12-28-2007, 07:52 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
I would check the reverb tank as well. try everything you can, make sure it's tight and well secured. Try unplugging it all together to see if it makes a difference.
If not. Then take it to an amp tech or return the amp for another valveking or another model amplifier.
Old 12-29-2007, 09:32 AM
millzy  is offline
yea yea..without even looking at this thread..before hand i had noticed it was loose..so i tightened it well just there now.. ive tightened as many things as possible...
strange situations huh
Old 12-29-2007, 09:49 AM
S-man  is offline
More like common problems.
Old 12-29-2007, 09:57 AM
millzy  is offline
yea yea
just has a matter of interest...s-man?
what was the reasons that put you off buying it?
Old 12-29-2007, 10:21 AM
S-man  is offline
Buzzing.
Old 12-30-2007, 08:13 AM
millzy  is offline
how did u hear about that..i didnt see any place complaining of the buzz
Old 12-30-2007, 11:02 AM
S-man  is offline
I played through it.
Old 12-30-2007, 12:51 PM
millzy  is offline
ahh cool
i played through it as-well but i dont recall these problems..but tightening the reverb tank did a bit of difference..and i tightened it a lot earlier on today so ill get back
Old 12-30-2007, 02:14 PM
martyfriedman86  is offline
Posts: 155  -  iTrader: (0)
buzzing may be caused by a defective tubes.
many amps are sold with tubes in bad conditions
you should check preamp tubes (i beleive the first and second 12ax7) and the output tubes (a couple of 6l6s)
Old 12-30-2007, 02:16 PM
millzy  is offline
yep..3 x 12AX7's and 4 x 6l6GC..i hadda look...took them out and they seemed fine
manufactured by ruby those of whom seem of a reputal brand
preamp tube
Problems with EMG 85 pickup installation LonePhantom Pickups & wiring 12 08-23-2005 06:03 PM
Problems with Edge... Shredcows Tech: Setup, Repairs and Mods 1 02-01-2005 10:00 AM
my new js and problems cakewalkr7 JS (Satriani Model) Ibanez Guitars 1 01-08-2004 01:47 PM
Rg 3120 Problems. ANNOYING PROBLEMS!!!! Given to Fly J-Custom, USA Custom & Prestige Ibanez Guitars 20 05-24-2003 02:24 PM
new trem problems...from a different perspective btweensunandmoon Tech: Setup, Repairs and Mods 11 05-13-2003 12:47 AM
