Gear and Equipment
Pedal Cables
Gear and Equipment
03-14-2008, 08:04 PM
ixelion
Posts: 48 - iTrader: (
Pedal Cables
I am currently using cheap right angle plugs that cause noise and take up to much space.
I have seen these right angle plugs that are very flat so the pedals sit closer together.
They kinda look like these:
I am open to kits as well.
ixelion
Find all posts by ixelion
03-14-2008, 08:07 PM
waylay00
Posts: 3,763 - iTrader: (
Re: Pedal Cables
Lava ELCs...
http://www.lavacable.com/lavaelc.htm
Had George Ls but these are ten times better IMO.
waylay00
Find all posts by waylay00
03-14-2008, 08:22 PM
microdmitry
Posts: 1,687 - iTrader: (
Re: Pedal Cables
Eighteen bucks for a six inch cable? WTF?
I just made mine myself. Those angle Switchcraft plugs aren't cheap and soldering to them takes some skill, but they're "only" $3.50 apiece, which means each cable is less than $8 and it's the exact length you need.
microdmitry
Find all posts by microdmitry
03-14-2008, 08:47 PM
ixelion
Re: Pedal Cables
None of the lava ones are flat they look like regular cables.
The switchcraft ones look good but I want easy assembly
ixelion
what looper pedal paul gilbert
what is the pedal board rigs
what distortion pedal can take guitars string 10-60
What amp sounds good with the Jemini pedal?
marshall jtm 30 how to connect effect pedal to send return loop
FS 2nd Greatest Distortion Pedal Ever
elcid
07:24 PM
FS: Line6 Dr Distorto Tone Core Pedal with Feedbacker and Power Supply.
ibanezcollector
11:48 PM
pedal cables suggestions
bartman
Gear and Equipment
04:24 AM
Pedal Board Design?
Cycovision
Gear and Equipment
01:03 PM
Possibly the best pedal I've ever owned
jay ratkowski
Gear and Equipment
31
08-02-2001
03:54 PM
06:47 PM
