Old 06-05-2008, 12:53 PM
axemanrio  is offline
Posts: 992  -  iTrader: (13)
Pedal power supply recommendations?
I've grown out of this Boss BCB-60 pedal board and will be selling it as soon as I find an alternative. Meanwhile, I have started shopping for power supplies and after reading up a bit on what's available, here are my choices:
Godlyke PA9 Power-All - £30
Visual Sound 1 SPOT - £30
Diago Powerstation - £55
Johnnyshredfreak 1500MA 9V Supply (same as Diago?) - £12 + cables
My requirements are not very complicated, I have all 9v pedals and one 18v pedal. I don't mind powering the CryBaby with dual 9V batteries but would prefer not to. My pedal setup will be:
Tuner » CryBaby » MXR dynacomp » Sansamp GT2 » Boss OD-20 » Satchurator (soon) » iSP Decimator » Boss Super Chorus » Digitech Delay.
All power supplies I've listed have automatic voltage regulation but none of them can power 18V pedals. Am I stuck with that or is there something I can do to these power supplies to enable them to power an 18V pedal in the same chain?
Alternatively, I'd have to spend the extra dough and get a Voodoo Labs Pedal Power 2, or opt for a DC Brick but I haven't heard good things about the Brick.
Thoughts? Suggestions?
Thanks!
Old 06-05-2008, 12:59 PM
Repner  is offline
Posts: 99  -  iTrader: (0)
Re: Pedal power supply recommendations?
As far as I know, the Voodoo Lab Pedal Power can power both 18v and 9v, if you are willing to sacrifice more money.
Other than that, I'm no expert on the other power supplies.
Old 06-05-2008, 01:01 PM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
I have the VL Pedal Power and its definately the one I'd go with
Old 06-05-2008, 03:04 PM
Lifeofsobriety  is offline
Posts: 197  -  iTrader: (2)
Not sure if this is ok as I am no expert but if not Im sure someone will correct me.
I have the Godlyke Power all and its not bad. It comes with adapters for many different applications, and I was thinking to power the wah you could use one of the adapters that hook straight onto a 9v battery clip, then use a battery on the other one or use two of the plugs on the godlyke and plug them into the batterys. Does that make sense? So you are using the battery clips instead of the DC jack to power it.
Just a thought, but it would probly be easier to buy one that could power it that just costs a bit more. It would make it neater at least.
Old 06-05-2008, 03:05 PM
I was afraid I'd get this reaction even though I did not want to spend more than £50 Anyway, I'm bidding on a Voodoo unit, comes with no cables so hoping to snag it for less.
Thanks for your responses!
Old 06-05-2008, 03:09 PM
7Plagues  is offline
Posts: 515  -  iTrader: (1)
I have a BRICK, which does 9V, 18V and I believe 12V or something. They are great little gadgets for guitarists that use alot of pedals.
Old 06-05-2008, 03:12 PM
chaos731  is offline
Posts: 489  -  iTrader: (6)
I have two of the Voodoo Labs Pedal Power 2 Plus boxes, and they're absolutely, positively the most versatile, high-quality pedal power supplies I've ever owned. I have a 1-spot as a backup, and it's pretty nice, too, and it's certainly cheaper, but the Voodoo Labs options are totally worth the money.
Old 06-05-2008, 04:50 PM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
I've got the Dunlop power brick and I like it. It's got the brightest LED I've ever seen on a pedal, so it must be good right? It powers a bunch of 9V and two 18V pedals . . .
Old 06-05-2008, 05:56 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Pedal Power II Plus
No other option IMO...
Old 06-05-2008, 06:22 PM
Alright, considering the Pedal Power 2 - how many pedals can this unit power? I will probably have no more than 10 pedals, that includes one 18v pedal.
Old 06-05-2008, 06:57 PM
Dantesstudio  is offline
Posts: 133  -  iTrader: (0)
Thumbs up
I absolutly agree. I do the same thing with just one vodoo lab. They are great.
Old 06-05-2008, 10:36 PM
waylay00  is offline
The PP 2 Plus comes with 6 standard 9v cables (and a few other odd ones). For your situation, you're going to need to purchase an 18v cable (I believe it takes two spots...I could be wrong), and some Y-cables (so you can power two standard 9v pedals off one output). That should easily cover your 10 pedals.
Old 06-05-2008, 11:59 PM
I just counted my brick's outputs and there are 7 9V and 3 18V outputs. Totalling 10.
Old 06-06-2008, 04:10 AM
Thanks man, that helps... Voodoo does have many additional cables on their site as well, so I should be good to go.
Old 06-06-2008, 06:35 AM
Repner  is offline
That's what I plan to do with my Dunlop Rack Wah when I get it. It uses a DC power supply so I can't put it in a UK Power Conditioner (which requires special male IEC connectors), and uses 24V. So I can use the Voodoo Lab PP2 plus.
isp decimator, rack wah, voodoo lab, voodoo labs
SKB PS-45 pedalboard - power supply warning microdmitry Gear and Equipment 0 03-30-2008 01:36 AM
Power Adapters for a Pedal Board slugman Gear and Equipment 10 08-09-2007 09:57 PM
Pedal power supplies - anyone getting noise? Ant1981 Gear and Equipment 47 02-24-2006 09:59 PM
Tapping MIDI phantom power for multiple pedals bduersch Gear and Equipment 0 02-21-2005 04:11 PM
EL-34 power tubes. Recommendations please? nukem2k5 Tech: Setup, Repairs and Mods 7 11-03-2004 01:18 AM
