Old 02-13-2006, 07:27 AM
EL-CeeDee  is offline
Posts: 484  -  iTrader: (0)
pick attack sound
Hiya there !
I was wondering...
How can one control the amount of pick attack sound in a distorted guitar ?
Right now, I hear them clearly, which is cool for fast runs ( TRRRRRR ), but not so much for slow, sensitive passages.
Is it the pickups ?
Is it the distortion ?
Is it a certain frequency ?
Is it my technique ?
And another: Why do I hear slides so loud on my distorted sounds ? Sliding a power chord ( I know, I'm evil ) is almost impossible right now soundwise..
Both my legacy head and MP-2 sounds have the same issue. Guitars used: Jem7PBK(check out my thread on it at the tech,repairs and mods if you're a setup specialist), JPM100P3 and a malmsteen strat.
Old 02-13-2006, 10:32 AM
giannifive  is offline
Posts: 484  -  iTrader: (8)
Re: pick attack sound
I believe it has to do with the pickup height. Try lowering the pickups and see if you get less attack.
Old 02-13-2006, 10:56 AM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
It's got a lot to do with compression. more compression=more pick noise
~K
Old 02-13-2006, 05:00 PM
compressor is switched off. However you have some natural compression on distortion ofcourse, maybe lower it a bit.
I'll try both ! Thanks !
edit: typo
Old 02-13-2006, 07:23 PM
red5  is offline
Posts: 2,639  -  iTrader: (0)
Something else I didn't see mentioned - for a smooth sound I slide my finger up the string with one finger wherever possible, like Vai does if you've seen him play live. For more pick attack I use multiple fingers and pick the string as needed. I don't really think about it either, I know what sound I want, so it's hard to explain.
malmsteen strat, pickup height
Can I make my RG sound like a Fender Strat? Need some help... Azrael Tech: Setup, Repairs and Mods 25 04-24-2007 02:00 AM
billy duffy+the cult sound, new+old help please? nightfiend14 Gear and Equipment 4 02-05-2006 03:14 AM
Your sound Allen Garrow Dave Weiner Official Forum Archive (SEE NEW LOCATION) 7 07-29-2005 06:58 AM
How do you get this lead sound? moro Gear and Equipment 13 03-18-2005 02:33 PM
Distortion sound : V-AMP(2) or LINE 6 POD (XT) JEAPSON Gear and Equipment 13 08-08-2003 04:08 PM
