Old 10-18-2003, 02:08 AM
keithb  is offline
Posts: 163  -  iTrader: (1)
Pick noise
I've been working on my tone alot lately, and I can't seem to get rid of the noise the pick makes when it touches the strings. I get a loud scratch/click noise before every note, especially noticable when I'm using higher gain. I'm guessing this is in part due to my technique - what should I change?
I use Dunlop Gator Grip 1.14mm picks (blue) - maybe I should try something thinner/slicker?
Old 10-18-2003, 03:26 AM
Jupiter  is offline
Posts: 344  -  iTrader: (1)
I find that when i use a tad too much compression on my Line 6 AX212, it will bring out the noises my pick makes up a lot. What kind of amp/effects are you using?
Old 10-18-2003, 04:18 AM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
yep...it's all about the comression
~K
Old 10-18-2003, 04:48 AM
keithb  is offline
I'm using a Line6 Spider, no effects and no compression. Of course the pick noise gets worse when I start dialing in reverb and delay...
Old 10-18-2003, 05:53 AM
microdmitry  is offline
Posts: 1,687  -  iTrader: (4)
Just get used to it. Listen to Paul Gilbert's playing for example. He uses this "noise" to emphasize the crispness of his picking technique. Also remember, the faster your pick moves (faster doesn't mean increasing the length of a stroke, though) the shorter this initial noise will be.
Old 10-18-2003, 06:38 AM
ns9  is offline
Posts: 223  -  iTrader: (3)
I was lmao until I saw the "i" in the last word...oh well...thought is was going to be a humerous discussion....
paul gilbert, picking technique
