Old 07-27-2001, 03:58 AM
kylemac  is offline
Posts: 30  -  iTrader: (0)
Pickup Selector - different pickups for different sounds
alright i have a a couple questions for you forum gurus. *
1. Are there any pickups for a jem7dbk that mimic or are very close to the lone star strat pickups?
2. If i am looking to play a mixture of some pearl jam, ozzy osbourne, ac/dc, slash, vai, van halen stuff.....which pickups should i go for? *
I currently have factory installed evo's at the neck and bridge in a jem7dbk. *Are there different pickups i want, or a mixture of a couple different ones? *Or are the ones i have great? *Thanks for all your help!
Old 07-27-2001, 08:41 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Pickup Selector
I think it's hard to find a p-up for all that stuff!!!
You better watch out for something very versatile, like EMGs, and run them thru a multiFX.
You cannot play AC/DC and Vai' stuff with the same p-ups, unless you have some pedals, or a multiFX!
my 0.02
nuno
Old 07-27-2001, 10:47 AM
Gabe Nickelson  is offline
Posts: 961  -  iTrader: (0)
Pickup Selector
Wow thats big request. *Unless you have a Roland VG8 you might have some problems. *I could suggest some coil taps on your humbuckers to get some of the sounds you need.
Gabe
Old 07-27-2001, 10:51 AM
LGMT  is offline
Posts: 364  -  iTrader: (0)
Pickup Selector
Do you custom order your guitar ?
Because DBK don't come with EVO's.
Old 07-27-2001, 11:47 AM
kylemac  is offline
Pickup Selector
yes the guitar was custom ordered, factory installed with evo's. *Hmm yeah it is a big range, lemme shorten it up to stuff with ac/dc, ozzy, van halen and slash.....actually i didnt really shorten it all that much, but thats all the kind of stuff i play.
Old 07-27-2001, 03:59 PM
Pickup Selector
Then if you have EVO's then your current pickups should suit you just fine. *Randy, Zakk, Jake, Eddie, Slash all use(d) humbuckers for the most part. *My new guitar will have a breed bridge pickup, however.
Gabe
Old 07-27-2001, 05:00 PM
ripl3y  is offline
Posts: 747  -  iTrader: (0)
Pickup Selector
Ok,
AC/DC, Ozzy (Zakk, Randy or Tone?), Slash.
The sound of a guitar doesn't rely too much on it's wood content (although a lot of people think different) it's probably about 65% pups, 35% wood or maybe even less on the wood side, up to the point of 85% pups, 15% wood by some recent tests.
What the wood will do is "contour" the sound as opposed to drastically change it. But that contour is also what can adjust the sound.
You can get many pups that will override everything and just shape the sound as they see fit. But these do tend to lack the character of the slight control the wood has over it and this is the point where you start to rely on EQ's.
You can hear these differences in woods that have tops.
i.e. a Tone Zone in a solid Mahogany bodied guitar has a little more boom that in a Mahogany guitar with a maple top, but unless you tweak the amp setting's it's not all that noticeable.
I too have a 7D and even though the wood (basswood) doesn't have any real noticeable characteristics over the sound (being a sort of middling wood) it does rely on pickups for the crutch of it's sound.
The TZ's work well with Basswood, even though you find them mainly in Mahogany guitars.
In basswood they crunch a little more (bridge position) and a great neck option for your sound is a FRED in the
neck. These guys really work more with the wood instead of the opposite, it's a difficult thing to explain, but having traded many emails with Dimarzio (for info on the pups) and an established U.K. luthier (for info on wood characteristics) I came to my conclusions.
Good luck in your search, and stick with Dimarzio.
They have the exchange policy (I don't know if Seymour have the same, someone please correct me if I'm wrong, as Seymour also offer some great pups)
Cheers
Steve
P.S. Don't limit yourself to the pups I have mentioned as these are only ones I've had most experience with.
Also check the Breeds. They are often overlooked as an after-purchase addition but do offer a sort of higher output FRED quality.
breed bridge, bridge pickup, bridge position, coil tap, mahogany guitars, pearl jam, strat pickups, tone zone, van halen
