Old 08-23-2007, 11:57 AM
Mission1979  is offline
Posts: 315  -  iTrader: (6)
Red face
Please put these in order for me!
Please show me the order for the best results please with the following gear.
Boss DS-1
Bad Horsie 2 Wah
Digitech Whammy
Boss CH-1 Chorus
MXR Phase 90
Ibanez TS-808(I only use this or DS-1 at time but I have them both in chain)
also soon to have a PT-80 Digital Delay i'm putting together
all with 7VWh and a Laney VC15 amp (it has effects loop but i've never used one)
All help appreciated.
Thanks
Old 08-23-2007, 12:04 PM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
Re: Please put these in order for me!
My choice would be:
7VWH>Wah>Whammy>DS-1>TS-808>Phase 90>CH-1>PT-80>AMP
I'd try the PT-80, CH-1 and Phase 90 in the FX loop.
Old 08-23-2007, 12:59 PM
Thanks, tried that sounds pretty good, phase 90 wasn't right in effects loop though. There was quite a change in volume when the pedal was engaged. Probably 50%. That layout was similar to how I had it bar I had the Whammy between the TS-808 and the phase 90.
So 7Vwh=>Wah=>DS-1=>Ts-808=>Whammy=>Phase 90=>CH-1=>Amp
Old 08-23-2007, 02:59 PM
bammbamm  is offline
I think I would try the whammy post distortion, just for kicks and swap the 808 with the DS1 so you could cascade the two should you want to use the 808 as a boost.
Guitar>Wah>Phaser>TS-808>Ds-1>Whammy>Chorus>Amp
The phaser in front will sound more intense.
Bamm
Old 08-23-2007, 06:17 PM
Quiksilver98  is offline
Posts: 138  -  iTrader: (0)
yeah , I would put it all in front. Maybe not the phaser, I might've put that int he FX loop of doom.
Old 08-24-2007, 09:38 AM
Re: Please put these in order for me! +PSU advice!!
I would put the phaser in the loop but I can't do with the drop in volume when its engaged.
I think i've got it nearly right but I admit I haven't tried every permutation yet.
Also need advice on a power supply with enough output for this gear. I'm not bothered for the whammy as that comes with its own PSU but I've heard that wah takes quite a lot of powering and the 5 way PSU i'm using at the moment is only 450mA.
PS Must have 18V Output to power delay
Thanks
digitech whammy, mxr phase
3 Boss pedals, which order is best? bbovee Gear and Equipment 15 09-20-2011 10:33 PM
Looking for online dealer to order Dimarzio pickup from toneboy Pickups & wiring 14 04-05-2006 09:47 AM
When can i order pedals from U.S. or europe Dave Goodland Gear and Equipment 6 05-06-2003 05:44 PM
DiMarzio Straplock installation - In what order do I put thi Anonymous Tech: Setup, Repairs and Mods 5 07-05-2001 10:20 AM
Anyone tried to order Custom picks from Pickworld? - www.pic cowcowcow Gear and Equipment 8 04-12-2001 09:22 AM
