Old 02-21-2002, 11:45 PM
Darin W  is offline
Posts: 75  -  iTrader: (0)
Pod into Legacy (efx return) - Sounds very tight and easy to
I have always liked the Pod (2.0) but it sounded bright and shrilly when cranked through a power amp. *I tried running it into the front of the Legacy but it didn't sound so GREAT. * Then I tried it into the return, still just ok. *Then I ran it throught a Rocktron Multivalve then ito the Legacy return. Now I'm happy. *I can use the multivalve to EQ the POD before it hits the power amp/Legacy. *We all know the Legacy has big semi smooth tone crancked, but at reasonable levels, it's a little tough to get all the smooth gain you want for lead playing. *
*I've also done this, run the DS-1 into the lead channel with Vai's settings. with a comp pedal. Didn't like it. *I did however like the DS-1 into the clean channel, and I used an overdrive pedal infront of that to get a little mors gain, because I had the DS-1 setr for "crunch". *That sounded good, also using the Multivalve as an EQ in the loop.
But I wanted somethin a little "tighter", more like Petrucci. *The POD so far gives me that. *
Oh, I put an Evolution in my VDY Jem, WAY BIG difference over the PAF (?). *And I just got my NEW PRS custom guitar with ChromeIllusion paint, Ebony fret board and Dragon 1's, coil tap 3 way. *Very sweet.
It cleans up better than all my other guitars when rolling the volume back on the Lead channel. *
Has anyone else had success with their POD?
Darin
Old 02-22-2002, 12:24 AM
Carlo  is offline
Posts: 835  -  iTrader: (0)
I've been doing a lot of direct-recording with my POD lately. *Now matter how much I tweak the knobs, i was still very unhappy with its sound. *But after using the graphic eq on my Cakewalk, the sound improved dramatically and I was happy
When I get a real amp, maybe I'll do the same thing you did. *It sounds like a cool idea.
Old 02-22-2002, 01:33 AM
Kremlin  is offline
Posts: 520  -  iTrader: (0)
Woah.. what I want to know is how much a custom PRS cost you.
Old 02-22-2002, 02:18 AM
Darin W  is offline
The price is in the $3,900 range. *But worth every penny. *
Darin
coil tap, custom guitar, ebony fret board, fret board, overdrive pedal, power amp
