Gear and Equipment
POD xt PRO with combo amp ?
Gear and Equipment
08-26-2004, 05:29 PM
megadeth
Posts: 1,221 - iTrader: (
hey...
i have been told by a handful of guyz that POD xt pro is a direct recording thingy and if i use it with my
marshall amp
, it'll probably suck ass !! is it true ?!?!
so if i turn off the amp simulation (like gt6) and use the unit as effects box or something ,then will the sound remaing crappy as told previously ?!?!
PS - I have MARSHALL AVT20
megadeth
Visit megadeth's homepage!
Find all posts by megadeth
08-26-2004, 06:04 PM
pawel
Posts: 2,656 - iTrader: (
Aren't you selling the amp?
If your amp has an effects loop, you should have no problem running the Pod either as a preamp/fx box. Of course it won't sound as good as with a nice
tube power amp
, but the sounds coming from the POD shouldn't be that badly affected....
pawel
Find all posts by pawel
08-26-2004, 07:06 PM
megadeth
pawel
If your amp has an effects loop, you should have no problem running the Pod either as a preamp/fx box. Of course it won't sound as good as with a nice tube
power amp
i am in a fix right now...i also have a gt6 ...so dunno what to do
megadeth
08-26-2004, 08:23 PM
pawel
What about running the GT-6 into a power amp? Many people enjoy the tone they get out of the GT-6 and it is considered to be a good unit. Just try tweaking it, and go to a store and play with the POD to see if you like it better....
Ok, the AVT20 does not have an FX loop, so I would suggest that if you plan to us4e the GT-6 or a POD, an amp with a fx loop would be a good idea...
pawel
08-26-2004, 10:56 PM
vai n maiden
Posts: 215 - iTrader: (
Reviews: 3
I tried it with a cheap marshall and it did indeed suck ass. Steer clear.
vai n maiden
Find all posts by vai n maiden
08-27-2004, 03:28 AM
dp15655
Posts: 198 - iTrader: (
Trade in the Marshall for a Tech 21 Power Engine and prepare to stand amazed...
dp15655
Find all posts by dp15655
08-27-2004, 05:15 AM
megadeth
what i am unable to understand is that both gt6 and pod have amp simulations but gt6 can be used with a
combo amp
.. but a pod can't be..if the preamp is the only thing then can i turn off the preamp from pod or gt6 then my processor will be juss like a bunch of individual effects...right ?!?!
megadeth
08-27-2004, 07:52 AM
themaidenmaniac
Posts: 379 - iTrader: (
i've never heard that before... its all horrible horrible lies! Well, probably...
friends of mine have no trouble using their pods with combo amps and it sounds good too.
themaidenmaniac
Find all posts by themaidenmaniac
08-27-2004, 07:53 AM
themaidenmaniac
I'd be interest to know what the sound comparision is like between GT6 and pod xt as i almost went down the road of line 6...
So in your opinion, which has the better sound qualities?
Cheerz
themaidenmaniac
08-27-2004, 07:59 AM
screamndemon69
Posts: 5,676 - iTrader: (
i think a flat response power amp like the Roland JC is probably the perfect mix for a POD. the results are exactly the same coming out of as they are going in.
screamndemon69
Find all posts by screamndemon69
08-27-2004, 09:42 AM
Patrick Deno
Posts: 478 - iTrader: (
Just thought I'd interject this if no one had seen it before:
http://www.atomicamps.com/index.html
LJ
Patrick Deno
Visit Patrick Deno's homepage!
Find all posts by Patrick Deno
08-27-2004, 11:19 AM
themaidenmaniac
now thats a damn strange amp...
themaidenmaniac
08-27-2004, 10:20 PM
Rudy
Posts: 277 - iTrader: (
How much is that Atomic? I think the power engine by tech 21 is @$300.
Rudy
Find all posts by Rudy
08-28-2004, 10:15 AM
rs70chgrrt
Posts: 61 - iTrader: (
check out this link
http://cgi.ebay.com/ws/eBayISAPI.dll...26591&rd=1
rs70chgrrt
Find all posts by rs70chgrrt
09-06-2004, 11:57 PM
Viper-sfm
Posts: 439 - iTrader: (
I'm guessing your friends don't really understand about this stuff, cause they are wrong. It'll only sound crappy if you don't know how to use your stuff. If you want to use the Marshall for good, you can use the pod for FX effects with no problems, just turn the preamp stuff off. That's what the bypass is for anyway.
Now, obviously, using the preamp on the pod plus the marshall (With dist off of course) won't sound fully right, cause you'll get the tone from one amp mixing with the mashall, so it may sound wierd...but then if you want the marshall sound, stuff the POD and use separate pedals or something like the GT-6...will work better...
IMO if you really want the pod though, just sell your marshall and get a simple Power Amp. That's what I'm planning to do. I already have a 100W poweramp (wich is rack-mountable...will look good with the POD), and then plug the POD before it.
Viper-sfm
Visit Viper-sfm's homepage!
Find all posts by Viper-sfm
combo amp
egnater tol
marshall amp
marshall avt
power amp
tube amp
tube power amp
how to open a jcm 900 combo
what ohm are the speakers in a 5150 combo
how to use GT-5 Boss with amp combo
how to take the tubes out of a 5150 combo
what should i replace emg 81 85 combo with
03:52 PM
