Old 08-16-2006, 01:47 AM
Tabsjunky  is offline
Posts: 56  -  iTrader: (2)
podxt live pedal help
Ok ok, so Im probably missing something really simple BUT how can I quickly change from using the volume pedal to the Wah pedal without having to go to the computer? Do I need to pick up an additional pedal?
Cheers
Old 08-16-2006, 02:13 AM
ibanezlover  is offline
Posts: 215  -  iTrader: (2)
Re: podxt live pedal help
You should beable to switch back and forth by pressing down on the pedal till it clicks. Isn't there a LED light that is green when volume pedal is on and red when wah pedal is activated?
Old 08-16-2006, 06:48 AM
GUARDiAN  is offline
Posts: 128  -  iTrader: (2)
Exactly.
The expression-pedal on the XTL works like the classic wah-pedal. Just step on it until it clicks and the green LED changes to red.
It's possible to change the assignment to Vol/FX-Modify. Check your configuration-settings if the pedal is configured to Vol/Wah.
Old 09-01-2006, 02:45 PM
I dont get any clicking, just smooth from back to front? Ive changed setting and still only get WAH or Volume. Is this a software issue? I just got the update and read that there are improvements that sounded cool but it doesnt work.
Old 09-01-2006, 03:22 PM
ibanezcollector  is offline
Posts: 3,206  -  iTrader: (29)
Images: 24
if your playing in front of a desk sitting down with carpet on the floor.
Your going to have to stand up and press fully forward, it doesnt click but the light will change.
Old 09-01-2006, 03:34 PM
stewmunny  is offline
Posts: 44  -  iTrader: (0)
It takes a bit of effort to change it so you need to stand up and put your weight on the tip of the pedal.
Old 09-02-2006, 02:03 PM
WOW....thanks everyone, I put the thing on the floor and it works fine. I guess pushing it with my hand wasnt enough pressure. ROCK ON!!
Old 09-02-2006, 07:51 PM
GUARDiAN  is offline
I had the same problem when I bought my first Cry Baby... I actually took it back to the store and told them it was broken.
Guess they had a real good laugh when I was outside the shop after they showed me how to activate it...
Old 09-02-2006, 07:53 PM
Ayrton  is offline
I am sure you were not the first person to do that.
volume pedal, wah pedal
PODxt or PODxt Live? Nordhauser Recording Studio 4 07-11-2006 05:08 AM
PODXT Live or BOSS GT8?? HaGa11aZ Gear and Equipment 25 05-01-2006 08:38 PM
PODXT LIVE new in the box ! 7stringer Classified Ads: Guitars and Gear 2 03-10-2006 07:44 PM
Line6 PodXT Live hurricane relief raffle from Eric's Guitars ecalcagnino Classified Ads: Guitars and Gear 5 09-30-2005 03:22 PM
WTT G-Major for PODXT Live Michael Jackson Classified Ads: Guitars and Gear 0 05-31-2005 05:47 PM
