Old 04-21-2005, 07:25 PM
SkaKid0991  is offline
Posts: 22  -  iTrader: (0)
power/pre amps
I'm sort of confused about how power and pre amps work.
I'm on the market for a new amp (because my solid state marshall is on the verge of death). I was looking into combos, for portability, and then running it into 2x12 or 4x12 when I need more power.
What would happen if you ran your guitar straight into a preamp and a power amp, or just a power amp? I think I've seen this on top of a cabinet, but it might have just been a weird head.
Would this work? Or do you need a head or a combo in there, too?
Sorry I'm so clueless...
Old 04-21-2005, 11:20 PM
The Madness Here  is offline
Posts: 249  -  iTrader: (0)
Re: power/pre amps
simply put (in reality its a tad more complicated) the pre-amp creates the 'character' of the sound while the power amp makes it loud.
so if you wanted to use a rackmount amp and another amp, then you'd want to run a pre-amp into the combo.
Old 04-21-2005, 11:52 PM
Re: power/pre amps
Ok. Well, what if you didn't want another amp? Could you run like
Guitar -> Preamp -> Power Amp -> Cabinet?
Old 04-22-2005, 12:18 AM
Re: power/pre amps
that's entirely possible. And precisely why you can buy seperate pre and power sections.
You can use a digital modelling pre-amp like a pod, and then another power amp, like say a mesa boogie 2:90.
typically one uses rackmountable tube pre amps and power amps as well as effects like
guitar > Mesa Boogie Tri-Axis > TC electronics G-Force > Mashall EL34 50/50 power amp > cabinet. However, if you're going to go the route of tube pre and power amps, it gets quite pricey. If you plan on starting out on a rack set up and you're on a budget, then you may want to use the power amp from an existing amp (like your marshall) and use a digital pre like the behringer v-amp or the pod.
with a fully rackmount amp you have other things to worry about, like midi control, power conditioning and many other things.
Old 04-22-2005, 12:25 AM
Re: power/pre amps
Alright, thanks. It sounds a lot more complicated (and expensive) than I had previously thought, so I think I'll just go the way of a combo and a cabinet or something. Thanks again.
Old 04-22-2005, 12:39 AM
Re: power/pre amps
many people on these boards actually use this method for amplification, they're also probably much better equipped to help you out, and probably make it seem a little less scary.
Old 04-22-2005, 01:19 AM
Re: power/pre amps
Yeah. I'm not so much worried about the fact that it's confusing, because I actually like playing with this stuff and learning about it. I don't know why but I was actually thinking this would be cheaper than buying something like a Mesa Rectifier Combo and a 2x12 cab. I now realize I was sadly mistaken
Old 04-22-2005, 03:38 AM
tobe  is offline
Posts: 260  -  iTrader: (5)
Re: power/pre amps
Hi man,
it depends on what kind of gear you look at. You can pick up say an old ADA MP-1 and a peavy power for pretty cheap, and get an inexpensive rack..for probably under 600 US. However, you are right in thinking it would be cheaper to get a 2x12 and a head, that might be of better quality. You can get, for example a mesa recto 2x12 head for like 350 on an auction site, plus shipping, and I have seen used Single rects go on the same site for 600-700...These of course just being examples based off your post. If you want un complicated..go with a head and a cabinet...racks have tons of options, and sometimes tons of headaches...however once you got it all sorted out it can make setting up and tearing down a breeze. Combo amps can be really cheap, like a Crate, or really expensive...I looked at a Bogner 2x12 combo that was 2,600.00. I personally do not like running a pre amp into another amp...Its kinda like running to pre amps in series into a power amp..its causes a lot of noise, and IMO results in some tones that are not always the pleasant...but differn't strokes for differn't folkes...Good luck in your search, Tobe
Old 04-22-2005, 06:39 AM
bpd111  is offline
Posts: 1,628  -  iTrader: (7)
Re: power/pre amps
Well, there are many options that would be cheaper than a rectifier combo and a 2x12, especially if you go second hand.
Let's talk about some basics first. Your dying Marshall combo is a combination of a pre-(before)amp (distortion/clean channels, EQ, etc.), power (the actual) amp and speakers.
The rack option simply separates the three. All this does is give you more options in the sound you're looking to put together. Is it easier to transport? I guess it could be, but I don't think portability is the reason to go with a rack set-up.
Basic rack set-up: Guitar >> Preamp >> Power Amp >> Speaker Cabinet.
Instead of a combo where you have a guitar, amp, and maybe some effects to transport, you've got the guitar, rack (they get pretty big) and a speaker cab.
You could buy a combo, like the Recitifier, that has a outlet for a extension cab for when you want more output.
Hope this clarifies some things.
Old 04-22-2005, 11:07 AM
Re: power/pre amps
Thanks everyone. I think I will go with a combo and a cab (for when I want more power). I like the idea of having more portability.
Tobe, where have you seen a 2x12 recto for 600-700? I assume your talking USD.
I've only seen second hand 1x12 recto combos for 1000.
Old 04-22-2005, 11:45 AM
Ferrous Lepidoptera  is offline
Posts: 472  -  iTrader: (0)
Re: power/pre amps
Just to be clear, many amps have an insert that allows bypassing the built-in preamp, so you aren't really putting two preamps in series. (It wasn't clear whether you were aware of that or not, from what you wrote.)
Old 04-22-2005, 02:09 PM
dangomles  is offline
Posts: 414  -  iTrader: (0)
Re: power/pre amps
Nice you have posted this thread, because i had the exact same doubts...
So, if i understand correctly, i can run my guitar like this: Guitar > Boss MT-2 > Line 6 Pod XT Live > (VHT) Valvulator Rackmount preamp (Which i dont have...YET!!!) > and through a Power amp (Which do you recommend?) > and finally, a Cabinet...
No combo, no head, right?
Old 04-22-2005, 02:16 PM
Re: power/pre amps
yes, but with both the pod AND the vht, you won't need the metal zone.
In fact, Id say that you don't even need both the pod AND the vht. If you like the sound of the vht, then Id say get a dedicated effects processor and ditch the pod since the pod is, itself, a pre-amp. Or, if you prefer the sound of the pod over the vht, you certainly don't need the vht.
Old 04-22-2005, 03:20 PM
Re: power/pre amps
I actually use the pod as a "pedal board" just for effects, but i think my sound definitely lacks of balls, and i think the vht will do the job...In fact, in the future i would like to get rid of the pod and but some single effects
Old 04-22-2005, 03:25 PM
Re: power/pre amps
buy* some single effects
amp distortion, combo amp, extension cab, mesa boogie, mesa rectifier, mesa recto, pedal board, power amp, power amps, preamp tube, recto cab, speaker cab, tube amp, tube amps
The Jemsite guide to amps Mr Orange Gear and Equipment 117 12-14-2011 08:05 AM
Car Audio Amps vs. Guitar Amps Jeff Gear and Equipment 8 09-01-2003 08:47 AM
Amps amps amps Grev Gear and Equipment 10 02-22-2003 02:18 AM
Review of my Voodoo Amps Modded TSL-100 Gresh Gear and Equipment 7 01-05-2003 10:08 PM
Amps, amps and more amps... - Suggestions...there are too ma carlos seo Gear and Equipment 4 05-17-2001 02:53 PM
