Old 02-12-2007, 07:30 PM
alex10  is offline
Posts: 698  -  iTrader: (1)
Question
powering multiple pedals with a daisy chain
please help guys,
i bought a daisy chain adapter off the Bay and it needs a seprate power adapter, i have one lying around but i'm not shure if it would work.
on the label of the adapter it says:
ac/ac adapter,
input: 240VAC 50Hz 60mA
output: 9VAC 600mA 5.4VA
the adapter will be used to power a boss ch-1 a boss ds-1 and dunlop crybaby.
Old 02-12-2007, 07:43 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: powering multiple pedals with a daisy chain
No. You need 9V DC not 9V AC.
Old 02-12-2007, 10:44 PM
Rotti  is offline
Posts: 3,341  -  iTrader: (8)
Plus it realy does have to be made for guitar pedals. Most of the "all purpose" power supplies will add a lot of noise to your sound.
Old 02-13-2007, 01:41 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
DONT PLUG IT INTO YOUR PEDALS !!!!!!!!!
when you say power adaptor, do you mean power supply ?
you need a good regulated 9v 300mA+ PSU to power your pedals - count on 100mA per pedal and select your supply on that basis...
post a pic of what you a re talking about !
Old 02-13-2007, 03:33 PM
al.  is offline
Posts: 152  -  iTrader: (0)
theres different types of daisy chains, theres the ones with the 1 female and 5 male chain i one so u can plug an adapter into the female input and pwoer 5 other pedals with the male connections...
and theres a 7 way male chain
well theres the ones i seen anyways...
So,
what u need is a boss PSA or PSU DC adapter which has a 1000mA output and a one of those 5 way daisy chains which has 1 female jack
What i used to do was Boss PSA adapter > 5 way dasiy chain, and have one jack gfoing into my tu tuner, THEN a 7 way daisy chain coming out of the tu tuner
the tu tuner has a 9v output as we know so i could power lots of pedals off the one 9v adapter
average pedal is 30mA or so... but there all diff
Old 02-17-2007, 09:34 AM
alex10  is offline
here's the pedal board
here's the female jack
here's the male jack
Old 02-17-2007, 01:04 PM
al.  is offline
the female jack looks weird but the male one looks aok, and does it work that way or what?
bassicaly u need an adapter into a daisy chain and ur good
Old 02-17-2007, 02:43 PM
Rotti  is offline
The proper adaptor.
Old 02-17-2007, 03:18 PM
al.  is offline
or drugs
dunlop crybaby, pedal board
powering pedals Saffron Shrimp Gear and Equipment 6 01-28-2007 11:58 PM
Powering Pedals Rotti Gear and Equipment 8 05-14-2005 02:09 AM
Tapping MIDI phantom power for multiple pedals bduersch Gear and Equipment 0 02-21-2005 04:11 PM
Powering my Pedals, recommendations adamcbest Gear and Equipment 13 07-25-2004 06:57 PM
