Old 08-22-2007, 05:30 PM
maliciousteve  is offline
Posts: 309  -  iTrader: (0)
Re: question about boosting solos
I use my EQ pedal in my Laney's FX loop. So when you turn it on you get a boost in mids as well as volume. Works perfectly.
Old 08-22-2007, 05:31 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
it's not a volume boost but turning down your tone knob during the rhythm and stuff will still push a lot of air and you'll still be heard, then when it's time for the solo's run the tone back up to get that extra brightness/cutting power you need.
Old 08-23-2007, 09:24 AM
dlp777  is offline
Posts: 100  -  iTrader: (1)
to close out this topic, the EQ pedal in the effects loop does exactly what I wanted. It bumped the volume quite a bit, had to keep turning the boost down until I found the right amount (about 20%-25% seems to work perfectly) but it's exactly what I've been searching for. Thanks a million!
Old 08-23-2007, 06:56 PM
kirk  is offline
Posts: 1,554  -  iTrader: (5)
Sounds like you found a solution. I had the same problem with my Legacy. I had a Mesa, with a lead boost that was perfect. I even had a Crate Class A Tube 1x12 that had a lead boost that cut through. But the Legacy? Ahh, no.
So, first I tried the volume pedal thing, after the preamp in the FX loop, but the ones I tried (passive EB and a Little Alligator) were way to sensitive and I'd go from 1-11 in a 1/16 of an inch.
The EQ (GE7) pedal saved my life. I am content to boost the 800, 1.6k and 3.2k - push the level to just a hair under 50% and BAM! I got it.
The EQ on the Legacy is so strange coming off of a Mesa - with my rig I have found that the best tone comes when I drop the bass to almost 50%, 75% mids, 65% treble and 65% presence. YMMV, but this is working well for me.
chorus pedal, distortion pedal, high gain amp, overdrive pedal, power tube saturation, preamp tube, stomp box, tube saturation, van halen, volume pedal, wah pedal
Jem7PBK - Question about the neck Martijn JEM and Universe Guitars 3 01-03-2007 09:04 AM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 03:41 PM
Bad horsie 2 question and Amp Question snorkthesick Gear and Equipment 1 04-11-2004 05:56 PM
WARNING: Stupid Floyd Question Ahead! Ugoyin Tech: Setup, Repairs and Mods 8 01-07-2004 08:56 PM
Recording Solos - Question - I could use some advice... CQ7String Gear and Equipment 16 02-28-2002 02:15 AM
