so, i have quite a few pedals. most of which are rather decent in the true bypass field. here is my chain
guitar-
zvex fuzz factory
535q wah
wh-1 whammy
keeley compresor
hbe compressor retro
rc booster
ac booster
bb preamp
-amp
effects send-
hbe psylicybe
hbe frostbite flanger
damage control timeline
-effects return
the two compressor pedals are for different styles. i use the hbe for subtle, sustainful compression, the keeley for country. anyways, i have been recently fighting for a perfect tone (or close to it) and got a 6 loop true bypass looper from loop master. obviously this helps big time with the wah and whammy. and for good measure i plugged the rest of the things that are in front of my amp into it as well. so here is my new
effects chain
guitar-
loop master
loop 1 send-zvex fuzz factory-loop 1 return
loop 2 send-535q wah-loop 2 return
loop 3 send-wh1 whammy-loop 3 return
loop 4 send-keeley compressor-loop 4 return
loop 5 send-hbe compressor retro-loop 5 return
loop 6 send-rc booster - ac booster - bb preamp-loop 6 return
-amp
effects send-
hbe psylicybe
-effects return
now there is a huge difference in the sound, since there is no tone suckage coming from the pedals before the amp. they were good before, excluding the wah and whammy, but now they are amazing.
now my understanding is that the pedals in an amps
effects loop shouldn't suck tone, because effects loops have a lower amount of signal required than the guitar intput on the amp (or something like that?). is this true? i have also heard of having a buffered effects loop on your amp. is that something that every effects loop should have?
and also, i think the theory of an effects loop is good sometimes, but completely contradicts itself other times. the whole idea is to put the modulation and timebased effects after the gain from the amp. so they put a send and return jack between the preamp and the power amp because in theory the gain and tone comes from the preamp tubes, and the volume comes from the power amp tubes and therefore the mod and time based effects have been put after the gain and tone in the amp.
well for me and many other people, the power amp plays a huge role in the tone and gain of my amp. i have a marshall 1987x reissue, and really the only way to get gain is from the power amp. therefore, the mod and timebased effects are not put after the gain stage of my amp. so is me putting these effects in the amps effects loop even serving a purpose? the whole theory just seems wrong
sorry for a long post. maybe it will spark lots of discussion
