Question about "THD Hot Plate" - Jemsite
Old 01-12-2013, 01:18 PM
Kilowatt4pwr  is offline
Posts: 0  -  iTrader: (0)
Good Day,
I recently had aquired a 50 watt non master volume plexi mk 2. I have a 16 ohm HOT PLATE THD. My amp has no effects loop. I was wondering if you could explain how to run the line out to use my effects. M13. Do I need another amp with a effects loop to use the return or do I need another power amp?? I cannot seem to hook everything up in order without dragging around extra speakers and amp heads. I have a 1971 basketweave plexi straight cab with 25 watt celestions. I hooked up the line out on the hot plate to effects return on a gallien kruger 250 ML, but the effects just came out of the 2x 5 inch speakers and when I hooked up extention speakers to hot plates speaker out extra output jack, nothing. Could u explain the simplest setup without having to drag around extra heads and speakers or the best set up?? THX a lot for helping me
Richie. E mail me at my email address when u have time.
CHEERS
80's RG Neck Plate question multo74 Other Ibanez Guitars (including Premiums) 4 12-06-2012 09:49 PM
Ibanez Reb Beach pickguard, Gibson ES-355 Switch Plate & 1966 Fender Neck Plate mayzan Classified Ads: Guitars and Gear 1 03-25-2011 08:57 AM
THD Hot Plate Ant1981 Gear and Equipment 1 12-14-2010 09:51 PM
Question about repainting Jem neck plate tzoranski Tech: Setup, Repairs and Mods 1 12-30-2009 12:47 AM
FS:Ibanez Pickups/Edge/RG7 Plate set/Neck plate Jem7RB MK Classified Ads: Guitars and Gear 10 02-22-2005 04:52 PM
Powered by
