Old 06-06-2008, 11:49 AM
wareyha  is offline
Posts: 23  -  iTrader: (0)
Question to the Carvin Legacy users
Hi, i'm vedat from turkey. I'm use carvin legacy combo
I turn on the amp on 50 watts from the switch.
But 4(all) of the power lamps still operational.
2 of them must be turned off,doesn't it?
In addition,I'm curious about the effect and booster pedals you are using.
What are your setups?
What will happen if I put a ibanez ts9 over drive in front of the drive channel?
Anyone with experince,please share your info.
At last,I attach electro harmonix because groove tubes is out of date.What is the performance difference of electro harmonix to groove?
If I install groove tubes again,would the sound change too much.
Last edited by wareyha; 06-06-2008 at 11:50 AM. Reason: Question to the Carvin Legacy users
Old 06-06-2008, 11:54 AM
wareyha  is offline
Re: Question to the Calvin Legacy users
I wrote the title wrong but cannot fix it.
carvin legacy combo, electro harmonix, groove tubes
Need help! Considering a Legacy 1/2 stack, But... nouromenon Gear and Equipment 8 06-15-2005 04:09 PM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 03:41 PM
Legacy Worth it? IbanezPrestigeBoy Gear and Equipment 13 12-08-2003 07:49 PM
Legacy effect loop - possible ground loop hum? bill h Gear and Equipment 4 08-12-2001 04:05 PM
Legacy owners/ users - comparisons wyzenhymer Gear and Equipment 7 01-07-2001 06:35 AM
