Old 06-22-2006, 04:19 PM
Algiman  is online
Posts: 2,553  -  iTrader: (14)
Rack experts - Switching Systems, Loopers etc.
I'm looking for something that will allow me to switch between 2 preamps in my rack, and has loops for a couple of pedals, rackmount tuner etc. From the stuff I've read, the Sound Sculpture Switchblade 8b seems to be perfect (and their customer service already has loads of points for answering all the questions I've been firing at them)
Does anyone have any experience with these units that would care to offer an unbiased opinion of them?
Any other units worth looking at?
I've already discounted the GCX because I can't be bothered with the non standard midi pin outs. Also, ideally, I don't want an external power adapter, I'd rather just power it straight from my power conditioner. And finally, standard 19" rackmounting. Not that I'm fussy at all!
Cheers.
Old 06-22-2006, 05:02 PM
Lefty Robb  is offline
Re: Rack experts - Switching Systems, Loopers etc.
Bob bradshaw could hook you up too..but it gets pricy..
http://www.customaudioelectronics.com/
Old 06-22-2006, 06:22 PM
Algiman  is online
.. and a stunningly long wait.
If I was after something unique that would be the way to go, but this is a fairly standard set up.
Anyone tried out Skrydstrup stuff?
Old 06-22-2006, 06:42 PM
I would imagine it would be the same with Skrydstrup's stuff..
Old 06-22-2006, 06:50 PM
Algiman  is online
You mean the long wait? No, it is available through a few retailers. Seems expensive for what it does though, in comparison to the Switchblade, which is why that is still my front runner.
Old 06-22-2006, 07:00 PM
tobe  is offline
Posts: 260  -  iTrader: (5)
Cheers.
Non standard midi out? The audio switcher has standard midi out, in, and throughs...With power through the midi to control the footcontroller. The power supply is a wall wart that connects directly from a standard outlet to the unit. Good luck, Tobe
Old 06-22-2006, 07:04 PM
no I was talking about the huge price...
Old 06-22-2006, 07:06 PM
Algiman  is online
No, Non standard midi PIN outs - if you read up on their website you see that although you can use other midi controlers you have to be careful:
Originally Posted by the GCX manual
Warning: The PEDAL IN jack on the GCX is not a standard MIDI In. It utilizes the two normally unused pins to provide 9 volts A.C. power for the Ground Control. Before connecting to a device other than the Ground Control, you must either use a cable without pins 1 and 3 wired, or verify that the MIDI Out of that device conforms to the MIDI specification which states that pins 1 and 3 are unconnected. Failure to do so can result in severe damage to your equipment. If you have any questions about this, please contact Digital Music Corporation's customer service department.
Old 06-22-2006, 07:07 PM
EL-CeeDee  is offline
Posts: 484  -  iTrader: (0)
Kitty hawk patch bayette
( was also featured under different name, can't remember. )
Lehle D-loop
Both quite affordable.
Be prepared for a lot of cables going in and out though !
To make my rack more portable I recently took out some of the loops
Real fun to play with though !
Old 06-22-2006, 07:08 PM
Algiman  is online
It is a European manufacturer so I would imagine that their stuff is horrifically expensive in the US, but over here it is just expensive
Old 06-22-2006, 08:14 PM
tobe  is offline
yeah, but most midi devices do not use pins 1 and 3, thats why they used them to run power. Also, you can disconnect the pins pretty easily....finally if you went with the GCX, not that it sounds like you want to, you really would want to get their controller anyways...they work well together, and are not too expensive. Good luck on your search!
Old 06-22-2006, 08:39 PM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
Um, you might be able to cobble something together using, say, the TC Electronics G-System, which has several switchable loops within its architecture - not exactly cheep, but it is, in addition to its switching capabilities, you get probably the best effects box on the planet!
Old 06-23-2006, 06:01 AM
Algiman  is online
Thanks for your suggestions:
Lehle D-loop - can't do what I want (not enough loops), and isn't 19" rackmount etc, but I nice box from what I've heard.
Kitty hawk patch bayette - I had thought that they went out of business years agao! I'll investigate some more, thanks.
TC Electronics G-System, Would possibly work, but not really designed for this job, besides I already have an effects unit so it would be a really inefficient way to spend my cash!
GCX - Still a possibility, and if I didn't already have a midi footcontroller I would go for their complete system.
Old 06-23-2006, 06:03 AM
Algiman  is online
Oh, and I'm still keen to hear from anyone with experience with the Sound Sculpture Switchblade 8b or Skrydstrup equipment.
Old 06-23-2006, 01:21 PM
The_Sleeper  is offline
Posts: 21  -  iTrader: (0)
Hey there,
I personally use Axess Electronics switchers (3 GRX4's ) and a DMC System Mix+ mixer/inteface, and a Rocktron All Access controller. Look into the Axess gear it's very well priced for what it does and Mario's customer service is second to none, and by none I mean absolutely none.
Seems like you're set on the Switchblade, there's awesome reviews about it and a ton of info to be found on it at www.hugeracksinc.com
Just do a keyword search & you'll have all the info you need from people who actually use it. I thought about getting one, but it's a little bit overkill for what I want.
Catch ya..........Joe
lexicon mpx, midi foot, midi footcontroller, volume pedal
Guitar rack system experts -I NEED HELP! - I urgently need a Ervin Martinez Gear and Equipment 45 03-22-2011 12:33 PM
rack newbie here, need help with choosing rack.. tonluvara Gear and Equipment 17 09-05-2005 08:21 PM
Rack experts out there, need suggestions AngelOfDeath Gear and Equipment 6 10-17-2003 12:30 PM
Switching systems... - Who uses what and why?.... davenit Gear and Equipment 6 01-31-2001 12:13 AM
