Old 10-05-2009, 08:09 AM
Cam-Vai  is offline
Posts: 313  -  iTrader: (0)
Reviews: 4
Re: Rack setup?Warning: lots of questions about Rocktron Prophesy 2 and rack/preamp g
Originally Posted by nickcoumbe View Post
I am a fan of rack stuff.
I bought a JMP1 and a multi effects unit, added a midi foot switch and haven't looked back.
I am between power amps at the moment, but I wouldn't consider trading racks for a head now to be honest.
They can be tricky to set up, but they are brilliant when they are working.
Cool!
i was looking at a jmp-1 when i was in japan cuz it was 300 bucks, but i couldnt carry it back
and they couldnt explain what it did! haha
but i got a couple of pedals
what power amps u got?
Old 10-05-2009, 08:31 AM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Originally Posted by Cam-Vai View Post
axe fx is wayyyyy tooooo expensive
Ok, consider this:
- How much will a preamp cost?
- How much will an effects unit cost?
- How much will a tube power amp cost?
- How much will a guitar cab cost?
If you buy an Axe-FX, you will never need to buy another preamp or another effects unit. Yes, it's that good.
If you buy an Axe-FX, you don't need a tube power amp. The Axe-FX also simulates tube power amp so you can buy a solid state amp. This will save you money in the long run because you won't have have to replace power tubes (which aren't cheap BTW).
If you buy an Axe-FX, you won't have to get a guitar cab. Because of the quality of the modeling in the Axe-FX, you're much better of running FRFR (full range, flat response) speakers (PA speakers or monitors) so the speakers don't color the sound the way guitar speakers do.
If you want to make things extra simple, you can just get power PA speakers or monitors and not even bother with a power amp. A lot of folks do this and they love it.
Old 10-05-2009, 10:28 AM
Sickbean  is offline
Posts: 262  -  iTrader: (0)
Now this sort of setup has me interested.
Can anyone honestly attest to this setup sounding as good as with traditional tube amp + 4x12 set ups? As in side by side Pepsi challenge type scenarios?
There arn't any music shops near me that stock the Axe FX, so I can't demo one myself.
Old 10-05-2009, 11:45 AM
toneboy  is offline
I can attest to it sounding amazing. I've tried my Ultra through a solid state power amp (PV something) through a pair of Mesa 112s and some PV 112 monitors.
It's one thing if you want to get a good tone through FRFR - that's easy - but if you want to feel the hairs on your forearm move when you play then you'll need big powered speakers (or big FRFR enclosures) to move the kind of air that a 412 can.
Old 10-05-2009, 03:09 PM
Sickbean  is offline
Unfortunately I have to say that in my 14 years of playing I've never played through a 4x12
But I see what you mean.
Old 10-05-2009, 03:17 PM
toneboy  is offline
I gave up on 412s a long time ago but yes, I'm just referring to the SPL (sound pressure level) that cabs with multiple speakers, especially closed-back 412s, can deliver.
Old 10-06-2009, 08:34 AM
Cam-Vai  is offline
Reviews: 4
i dont like 4x12
too biiiiig
i liek 2x12
mesa's especially they sound aboslutely amazing,
but i think prophesy and el34 is the one!
unless i find an absolutely amazing rack rig
Old 10-06-2009, 09:16 AM
Cam-Vai  is offline
Reviews: 4
hey presto
cataclysmicheal is using an el34 20/20 and a axe fx ultra
sounds amazing!!!
guitarmichael.com
and watch the one called threat signal - rational or something along those lines'
cam-vai
Old 10-06-2009, 01:32 PM
toneboy  is offline
hey presto
sounds amazing!!!
FWIW, you can probably save a few hundred bucks on the Axe-FX if you cruise the official boards and look for someone selling a Standard.
Also, if you do go the Axe-FX route, you owe it to yourself (and your wallet) to look into a solid state power amp and a FRFR cab. You really don't need a tube power amp with the Axe-FX and running it through a guitar cab just decreases the Axe-FX's flexibility.
Old 10-06-2009, 09:55 PM
Cam-Vai  is offline
Reviews: 4
my 'rents arent too pleased ive looked at the axe fx
haha
but hopefully whatever comes up cheap first im getting basically
but
can i work a moog mp-201 (like the foot controller) with prophesy or axe-fx?
cuz its alot cheaper than an all access and would be alot easier for me
thx heaps
cam-vai
Old 10-07-2009, 08:18 AM
toneboy  is offline
haha but hopefully whatever comes up cheap first im getting basically but can i work a moog mp-201 (like the foot controller) with prophesy or axe-fx? cuz its alot cheaper than an all access and would be alot easier for me
The MP201 isn't designed for guitarists - it's designed for keyboardists. Half of its features won't even work with guitar gear.
For a foot controller, look into the Behringer FCB1010. It's a great bang for the buck. The next step up would be the Rocktron MidiMate. It's a little more money but it's built a little better and you'll have to spend a little more money to get an expression pedal for wah or volume if you want that. Either option is still a lot less money than anything else out there.
Old 10-12-2009, 07:26 AM
Cam-Vai  is offline
Reviews: 4
sounds good!~
is the midimate programmable? can i assign a wah, flanger, maybe channel select? i.e. - clean/chorus to dirty/overdrive or something??
thx
cam-vai
Old 10-12-2009, 08:15 AM
toneboy  is offline
sounds good!~
You have to be careful about using the word "channel" when referring to anything dealing with MIDI. Processors like the Rocktron don't have "channels" for sounds, they have "presets" or "patches". MIDI uses channels for sending MIDI data (e.g. preset change, controller messages, etc).
Have you gone to Rocktron's site and read up on the Midi Mate? They have a manual available for download.
Old 10-15-2009, 02:18 AM
Cam-Vai  is offline
Reviews: 4
ok
turns out i cant do this:'(
if i buy them from america ill havbe ot mod them - liek an extra 3 grand, and its liek an extra 2 to buy them anyway
so im gettiung a mesa mk iv
played one and its heaven!
but is it as heavy as a prophecy?
amp, rack, vai
FS: Rocktron/Digitech rack gear Redwitch Classified Ads: Guitars and Gear 2 07-18-2009 11:49 AM
Wanted~ Rocktron Prophesy Preamp MorbidAngel Classified Ads: Guitars and Gear 0 04-05-2006 12:44 AM
rack gear questions analogcreature Gear and Equipment 12 09-05-2005 05:46 PM
Questions about my rack setup... ChrisReedSmith Gear and Equipment 4 01-14-2005 05:07 AM
