Old 10-27-2007, 10:52 AM
adamcbest  is offline
Posts: 870  -  iTrader: (0)
Rack Tube Power Amp - Single Channel
Hey guys,
Does anyone make a single channel tube power amp? I'm trying to make my mark IV rig a stereo rig using the Satellite out on the Mark IV. I know you can bridge the Carvin TS100, but that makes the power rating 100W where I run the Mark at 30W. Are there any other options other than the TS100 for a single channel? OR If you get a stereo Power amp and only use one channel, does that leave the other channels output transformer to burn up since there is no load. I'm not too too familiar with the workings of a 2 channel power amp, but i do know most only have one on/off and one standby switch.
Thanks
Old 10-27-2007, 11:00 AM
bpd111  is offline
Posts: 1,628  -  iTrader: (7)
Re: Rack Tube Power Amp - Single Channel
Mesa/Boogie's manuals say you can use one side of the amp without hurting it. On the unused side, turn the volume to zero, and the presence to 10. I use both my 50/50 and 20/20 in that way. I have had issues with the 50/50, but it's pretty old, and I don't attribute it to using the amp that way.
Old 10-27-2007, 11:05 AM
cool thanks. It might have helped if i read the manuals .
Old 10-27-2007, 03:29 PM
hirah  is offline
Posts: 135  -  iTrader: (4)
Reviews: 3
or you can find a mesa simul satellite that was made for this purpose. they made them as 1x12 combos, but you can also rackmount it like any short head/combo. there were 2 models, one with the graphic eq and simul class option. and one with out the eq or simulclass. great poweramp, though heavey as a mark 4. it's actually the same power section.
here it is in the top of the picture.
Old 10-27-2007, 10:51 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
whoa... how do those Simul-Satellites work? is that what's powering the quad-pre?
Reg
Old 10-28-2007, 08:24 AM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Randall RT250 - can be run as a 50/50 stereo power amp or a a switchable mono 50W amp. You get 2 power amp channels to switch between - you can have different valves in each so you get more tone choices. Great power amp but 'king heavy.
power amp, tube power amp
FS: 6+1 Space Powered Rack, Samson Power Amp toshiro Classified Ads: Guitars and Gear 0 05-24-2006 02:57 AM
FS: carvin TS100 tube power amp & Gator rack Koss Classified Ads: Guitars and Gear 14 03-03-2006 04:26 AM
Power tube tone vs. SS tone (not preamp) revsharp777 Gear and Equipment 20 06-08-2005 02:13 AM
Controlling DSL + a rack unit with a single footswitch 403 Gear and Equipment 14 03-05-2003 08:09 AM
Single rack space power amps - Opinions please wyzenhymer Gear and Equipment 3 06-10-2001 08:10 PM
