Old 02-12-2002, 12:27 AM
djrjems  is offline
Posts: 190  -  iTrader: (3)
Rack tuner - can I put a tuner in the effects loop? - I coul
Hi gang. *This seems like a silly question, but I haven't found any info on it so I figured I'd ask the forum . . .
Can I put a tuner in the effects loop? *I've got a Mesa Nomad combo amp and my rack is really simple . . . just a Rocktron Replifex. *I was thinking of adding a rack tuner (and possibly a power conditioner) to the rack. *Coincidentally, it's a three space soft case rack *
Because I'm strictly using the rack for effects (no preamps) can I put a tuner in the Mesa's effects loop without any problems? *I don't want to mess with a bunch of fancy routing just to get a tuner in the rack . . . if I can't just add it to the effects loop I'll forget about it and just use my hand held tuner.
I'd expect that the chain would look like this:
Mesa effects send -> Tuner in . . . Tuner out -> Rocktron in . . . Rocktron out -> Mesa effects return
Make sense?
Old 02-12-2002, 12:08 PM
oooo  is offline
Posts: 338  -  iTrader: (0)
I have a Korg Tone works DTR-2 in my FX loop of my Budda. *I've used it like that for years (with my VHT and a few other heads) W/O a problem. *Ideally, you should put it someplace out of the signal path ( Like a recording out or something) because the less stuff you have in your signal path the better for tone. *That being said, I notice no difference in tone with my DTR-2.
I set it up... Fx send from my Superdrive 30 (Budda) to the tuner in... out from the tuner to my G-Major... from there to the Fx return. *Works great. *
I also have a setting on my G-Major that basically mutes it (G-Major). *Since it is after the DTR-2 in the signal path I can tune in silence... yes I know the G-Major has a tuner, but the Korg unit blows it away by a mile!
hope that helps.
Old 02-12-2002, 04:56 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
hey DJR,
sorry for going out of your post but... what's in your avatar? home-made graphics RG? can you post a bigger pic of it? or send it to -m-@libero.it
thanx
nuno
Old 02-13-2002, 05:15 PM
bammbamm  is offline
I have a tuner in my system as well, but I don't put it in the signal path.
On the Mesa, there is usually a direct out, I would run a line from that to the tuner in, that should do the trick and not affect your tone.
Bamm
Old 02-13-2002, 05:24 PM
djrjems  is offline
Nuno . . . no problem! *I actually created a thread about this axe last summer. *It's my custom graphic RG770. *The top is a print of van Gogh's Starry Night. *I did nearly all the work myself. *Here's a link to the old thread about the guitar:*Dave's Starry Night RG770
Old 02-13-2002, 10:55 PM
djrjems  is offline
Thanks for the tips guys! *If I end up getting a rack tuner, I'll probably run the line to it from the Slave out or Recording out on the Nomad.
combo amp, mesa nomad
