Old 02-09-2006, 06:25 AM
isida.d  is offline
Posts: 299  -  iTrader: (0)
Recomended For Dropped C
What are recommended string guages for tuning down to dropped C?
Currently i'm using 10's for my SZ520 and wondered if there is a recomended minimum if your going that low.
Regards,
daniel
Old 02-09-2006, 07:23 AM
pawel  is offline
Posts: 2,656  -  iTrader: (3)
Re: Recomended For Dropped C
I would have chosen 12s (and 11s for D) for that tuning, but I use 10s in standard, so by default I'd go to a higher gauge for low tunings...
There are people who use 8s for D tunings, so you could probably get away with 9s or 10s in C. Depends on your touch as well...
edit: typos, typos, typos, and typos...and it was only a 2 line post!
Old 02-09-2006, 09:43 AM
Chud  is offline
Posts: 926  -  iTrader: (0)
Dropped C i would probably use .11's.
.12's seem a little bit too extreme for me
Old 02-09-2006, 10:10 AM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
I usually use an 11-56 set in C#, depends on how tight you need the low strings. Maybe buy a set of 10-52 and a single heavier guage(like 56 or 58 ) for the low C.
Old 02-09-2006, 10:27 AM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
I use either 11's or 12's. I don't even really notice much of a difference.
Old 02-09-2006, 10:41 AM
lyconxero  is offline
Posts: 1,469  -  iTrader: (0)
I use Ernie Ball power slinky's 11-48 and a 52 gauge string for the top. I like this set because it still feels a lot like 10's a half step down from standard.
Old 02-09-2006, 05:38 PM
guitardevil2005  is offline
Posts: 442  -  iTrader: (0)
personal preferense question
Old 02-11-2006, 05:52 PM
isida.d  is offline
fair enough, just incase there was some confusion i actually dont use 10's for dropped c, i meant tha ti used them currently for standard and wondered what people recomended for c, but now i havem y answers, thanks guys
Old 02-11-2006, 06:38 PM
buddroyce  is offline
I find that 10-52 works fine when setting up guitars for Drop C.
ChopTart  is offline
Posts: 1,390  -  iTrader: (1)
12 seems to be alrite for me, but I guess 11's could do fine also. You could customise and buy 2 sets, for a heavy bottom, but easy to bend top. I believe D'addario makes hybrid sets like these.
Old 02-12-2006, 01:27 PM
Progdude  is offline
Posts: 250  -  iTrader: (0)
I use 9s on the top and 10s on the bottom.
ernie ball, low strings, string guage, string guages
