Old 08-02-2005, 10:58 PM
eonblueapocalypse  is offline
Posts: 7  -  iTrader: (0)
recording bass heads
could anyone tell me if I need to have my bass head plugged into a cab when i record it direct via xlr out? Someone told me the head will fry if I dont have it plugged into the cab...thoughts?
Old 08-03-2005, 12:25 AM
AlexBLA  is offline
Posts: 200  -  iTrader: (0)
Re: recording bass heads
i dont think it matter... you just need the cabs to hear what it sounds like...try going to the manufactors website and downlaoding a pdf manual
Old 08-03-2005, 12:48 AM
knarfzednem  is offline
Posts: 91  -  iTrader: (0)
i hear tube amps will go out if you turn them on with no speakers connected,so be careful.
Old 08-03-2005, 01:25 AM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Amplifier plus Speaker Load = Good
Amplifier minus Speaker Load = VERY BAD
With no cab connected to your head, you'll most likely only fry your output transformer, but a competent amplifier repair shop will be able to fix you up for a few hundred or more, depending upon the power output of the amp. The more powerful the amp, the heavier the output tranny and thus the higher the price tag.
Seriously though, whoever told you it was cool to play without a speaker connected to the amp should have their head examined or split the cost of the repair bill. If you have a headphone jack that mutes the speaker when the phones are plugged in, that's OK, just be sure the cab is always connected and presenting a load to the output transformer whenever you have the amp plugged in to your power supply. Even in the case of inadvertantly turning on the power - with no guitar plugged in and no input signal present - you can do serious damage to your rig.
Old 08-03-2005, 03:42 AM
ok cool ..thanks for saving my ass from alot of hassle considering its not my amp.
thanks again
Old 08-03-2005, 12:25 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
Depends on the amp, if it is a solid state amp, it will most likely be fine. Tube amps have to have a load. What kind of amp is it? Check the manual, it should say "do not use without a speaker load connected" or something like that if it will hurt it.
Roger
Old 08-03-2005, 01:05 PM
It's a fender bassman 400 head ..solid state so i guess it would have been ok.
i recorded with it today, but used the cab so its ok..just thought id check before hand.
at least now i know.
Old 08-03-2005, 08:12 PM
ScottB  is offline
Images: 8
"Most" high power solid state heads have a thermal protector built into their circuitry. The minimum impedance rating should be listed on the rear panel near the speaker connection jacks. If the minimum load is, for example 4 ohms, connecting a speaker load of 2 ohms will cause the protector to open and the amp will shut itself off, thus protecting the transformer. The same goes for no speaker load - zero ohms - the thermal protector will shut the amp down until a load above the minimum is properly connected.
Old 08-03-2005, 08:43 PM
rgr  is offline
A dead short, i.e. a straight wire across the outputs, is 0 ohms, whereas an open, i.e. nothing connected, is infinite ohms, which is why it usually doesn't hurt ss power amps. Really, I studied this stuff for 4 years in college.
It doesn't work for tube amps though, they need a load across them.
You should still consult the manual first.
Roger
Old 08-04-2005, 12:26 AM
ScottB  is offline
Images: 8
Red face
Man do I feel like a dork! The last time I repaired my amp, I had to replace one of the input jacks. It was the 3 conductor, "shorting" type jack. I just checked the wiring schematic and the speaker outputs are the standard, "non-shorting" type.
Thanks for clearing up my misconception Roger.
Old 08-04-2005, 10:13 AM
rgr  is offline
No problem, I really wasn't trying to sound like an a$$, just didn't want anyone misled. An amp maker would never use a shorting jack on an output, maybe a switching jack that put a "dummy" load in place in case nothing was hooked up (Koch to name one). The reason for the input jack to short to ground it to kill noise when nothing is hooked to it.
Peace,
Roger
fender bassman, input jacks, power amp, power amps, solid state amp, solid state head, tube amp, tube amps
Anyone use the Variax Acoustic / Bass for recording? bduersch Other 6-string Guitars (non-Ibanez brand) 9 08-08-2005 02:19 PM
a thread for the bass player, littlegreenman Off-topic / Miscellaneous 21 08-07-2005 07:32 PM
Recording a bass guitar with a POD or similar? caprile Gear and Equipment 2 01-18-2005 01:17 AM
Under $200 Bass for a guitar player recording? Rudy Recording Studio 10 01-11-2004 11:26 AM
Bass Playin' - Not sounding like a guitarist playing a Bass dwswift Gear and Equipment 6 12-24-2001 05:40 PM
