Old 06-25-2009, 01:41 PM
Myst and rain  is offline
Posts: 3,474  -  iTrader: (0)
Question
Reducing background sounds while using SM57?
How can I reduce/eliminate background sounds? Will using this suffice? Due to the size of the room I'm in, I'm sitting about four steps away from the mic...
Old 06-25-2009, 01:53 PM
fretboardpyro  is offline
Posts: 311  -  iTrader: (0)
Reviews: 12
Re: Reducing background sounds while using SM57?
good start it'll take away some harshness of sounds, but not really too much background noise. what you need to do is create a small isolation screen about a foot and a half behind and to the sides of the mic but obviously in front of the amp. large egg crates mounted to board or foam rubber mounted to some kind of board are good for this as they will diffuse the sound. Also place everything on a rug or carpet to assist in removal of superflous vibration. Unless you are in an isolated studio or booth you will get some outside ambience.
Old 06-25-2009, 02:02 PM
shogun  is offline
Posts: 1,525  -  iTrader: (13)
1 turn up your amp
2 ??????
3 PROFIT
Old 06-25-2009, 02:41 PM
MattyG  is offline
Posts: 360  -  iTrader: (4)
I record guitars from a very small amp, which I mic up - the amp and the mic all fit into a large storage box which I place over them. Literally just place the box upside down over the amp and mic, with the wires coming out the side.
This works a treat for me.
Obviously it all depends on what gear you're using and how 'professional' your set up is etc....
Old 06-25-2009, 03:18 PM
Reviews: 12
now there's inginuity!
Old 06-25-2009, 04:03 PM
haha That's very interesting. The fact that the amp is in a closed space probably affects the sound, though. Not necessarily in a negative way, but still. It's interesting.
I don't know if me putting a screen behind the microphone, in the way you guys described is practical seeing the size of the room. But maybe I can move some furniture around and work something out.
This is also an interesting thing:
http://www.thomann.de/nl/the_tbone_micscreen.htm
But I don't know if I can attach that to the mic stand that I use. I should do some research on that.
Old 06-25-2009, 04:07 PM
Originally Posted by shogun View Post
1 turn up your amp
2 ??????
3 PROFIT
That was funny. lol
background, noise, reduce, sm57, sounds
background check for job shredmaster Off-topic / Miscellaneous 13 07-15-2008 10:35 PM
Made my own Myspace background Darin Off-topic / Miscellaneous 4 02-10-2008 01:15 AM
background music im working on hanban Multimedia: Music, Pictures & Sounds 11 09-03-2004 09:01 PM
How to eliminate background noise on some POD XT presets ? JEAPSON Gear and Equipment 4 01-22-2004 12:20 AM
Reducing bass frequency in neck pickup - Any ideas? rbjammin Tech: Setup, Repairs and Mods 9 06-27-2001 06:10 PM
