Old 04-26-2004, 08:48 AM
goth_fiend  is offline
Posts: 77  -  iTrader: (0)
rig help
right now im getting ready to buy a mosvalve 80 watt power amp, either a tech 21 psa 1 or a lee jackson perfect connection preamp, and building my own 2x12 cab using 100 watt celestions, now i was also thinking of putting a intellifex in there as well and building one solid enclosure for this, effectively making my own combo, do you think this setup could handle a progressive metal tone?
Old 04-26-2004, 01:54 PM
mike777  is offline
Posts: 656  -  iTrader: (0)
So you're thinking of including all of this into a single unit?
It sounds cool but I think it'll end up being a bit awkward in the end. You'll want to leave some cooling space between the rack units. I'm not too familiar with all of these pieces but I know the PSA1 a little bit. It doesn't sound like the result would be too top-heavy but if you ever go with an all-tube power amp-that could change. The overall sixe might be odd when lifting
The other thing I'm thinking about is that if you make this to safely accommodate the rig described above, it may be an inconvenience if you want to swap out one of the units for something of a bigger size. It may not fit in correctly along with the other units. Just something to think about.
Mike 777 Haug
Old 04-27-2004, 05:20 AM
Jammy  is offline
Posts: 868  -  iTrader: (1)
I was thinking of doing this aswell, to make my rack system a tad easier to transport - but I decided against when i bought a spring reverb unit, those things dont like to be vibrated by bass notes...
Old 04-27-2004, 05:44 AM
dp15655  is offline
Posts: 198  -  iTrader: (0)
EDIT: oops, wrong thread !
Old 04-27-2004, 07:12 AM
kent  is offline
Posts: 150  -  iTrader: (0)
Are you talking about getting the Tube Works Mosvalve 1160? If so, I can only give you my experiences with that amp. It sounds great but it definately has a sweet spot and if you get it too loud the tone gets brittle in a hurry. You better make sure it's loud enough for what you need and be sure to use 8ohm and not 16ohm speakers. Also, the pots on those power amps are notoriously bad. You need to look into getting them replaced as soon as possible to save yourself a real headache down the road. Again, it can be a perfect amp in the right setting, but I have definately been in situations where the volume was there but the tone was gone. In other words, it can get loud, it's just that your tone can fall apart at high settings. If I were you, I would look for the big brother to this amp which is the 1500. It's not that it gets louder, it's that you will have more headroom and your tone will retain its fidelity at higher volumes. Good luck.
Old 04-27-2004, 08:27 AM
actually the poweramp i was looking at is the mv-962 not the 1160, but i bet the same thing applies to what you said with it/
Old 04-28-2004, 02:01 AM
got the poweramp today, started designing the combo amp as well, thinking of going with a powdercoated sheet of diamond plate for the face, other then that all i know is that it will have either red, blue or silver tolex
Old 04-28-2004, 04:04 AM
Jammy  is offline
Cool. your ideas sound very "krank"
combo amp, lee jackson, ohm speaker, ohm speakers, power amp, power amps, rack system, spring reverb, tube power amp
