Gear and Equipment
Rocktron Chameleon 24bit DSP preamp
Gear and Equipment
07-10-2005, 10:09 PM
btangel
Posts: 541 - iTrader: (
I tried one of these with a fender customshop strat (these are a must have btw), and blew everything I've ever heard out of the water. Does anyone own one of these and would like to give some input? I'm particular interested in it's sound through a JEM. IMO it had the best gain I've ever heard. I'm ready to throw all my gear away for this little rack.
btangel
Visit btangel's homepage!
Find all posts by btangel
07-10-2005, 10:54 PM
rgr
Posts: 1,791 - iTrader: (
Re: Rocktron Chameleon 24bit DSP preamp
Was it the old style or the new Chameleon 2000s? I have one of the old made in USA ones as my main rig now, they are great sounding units. I like the older ones better, they don't have the "models" like the new ones, they have more EQs to set up, but are worth it. These were out way before Line 6 and the other digital modelers, and IMO, stilll blow them away. I also have an old Pro Gap preamp which is analog solid state and an old Intellifex. Starting to look like an old Rocktron ad here. I also have a new BBE 482i between the Chameleon and the
power amp
which makes it sound even better.
I love tubes, especially Marshall style amps, Mesa's never did it for me (I've had a Mark IV and a Rectifier), but the Chameleon makes it so easy to record and get great sounds at low volumes, it works better for me.
Roger
rgr
Find all posts by rgr
07-10-2005, 10:58 PM
btangel
the old ones. I LOVE THEM! I never tried the newer ones tho. But for DSP modeling these things sound better than anything I've ever heard. It might've been the noiseless PUs from that custom strat but wow
btangel
07-11-2005, 01:02 PM
revsharp777
Posts: 980 - iTrader: (
rgr
I also have a new BBE 482i between the Chameleon and the power amp which makes it sound even better.
Roger
Same here. I run a
Rocktron Chameleon
> BBE > Mesa 2:100. The Chameleon is AMAZING in its versatility. For the last 5 years, it's provided me the most BRUTAL distortion tones, super sweet leads, & the cleanest of cleans. What more could you want?
revsharp777
Visit revsharp777's homepage!
Find all posts by revsharp777
07-11-2005, 01:48 PM
bpd111
Posts: 1,628 - iTrader: (
I'm always on the market for a new preamp. I've found a chameleon for $199. It sounds like it sounds good, but it's gotta be simple to use. What's the learning curve like? (I don't like scrolling through menus, but I do like dedicated knobs.)
bpd111
Find all posts by bpd111
07-11-2005, 02:06 PM
rgr
They (the old ones) aren't the easiest to program, but after you do it for a while you get pretty quick at it. Figuring out the EQs is probably the toughest thing, but it really just takes an evening of experimentation. The Voodu Valves are also nice, I used to have one of those, may pick one up again.
The Chameleon 2000 seems to be set up more to compete with the PODs, etc..., it has 4 amp "models" to start with, clean, texas, british, and mega, and a more standard EQ. I like the fleixibility of the originals though.
Roger
rgr
07-11-2005, 10:34 PM
btangel
bpd111
:O where? If you happen to pass on it please let me know!
I also heard that they downsize the amount of EQ bands you can adjust on the newer ones. Some even say it sounds completely different from thd old ones. It's scrolling menus btw, which I'm use to because I own a BOSS GT-5.
Oh and could one of you explain the BBE? thx
btangel
07-12-2005, 04:43 AM
bpd111
btangel
I'm after an ADA MP1 at the moment. I found it online at Daddy's Junky Music. Type Rocktron in the search field & it should be the first item. They're located in the Northeast and they don't do mail order
http://www.daddys.com/content/usedgear/usedgear.shtml
P.S. I hope this post is within the rules.
bpd111
07-12-2005, 05:50 AM
btangel
yea...only for local pickups apparently. What a shame.
btangel
07-12-2005, 11:51 AM
rgr
http://www.bbesound.com/
Here's the one I use:
http://www.bbesound.com/products/maxim/482i.asp
, pretty much the standard for rack setups.
rgr
power amp
rack setup
rocktron chameleon
voodu valve
a really good preamp and a good reverb unit is all you need
how to repair a preamp
do I need a preamp with power amp
rocktron hush where to put it
what power amp goes best with a cae preamp
Rocktron Chameleon 2000
revsharp777
Gear and Equipment
11:45 PM
05:29 AM
