Old 10-03-2007, 01:42 PM
texshred777  is offline
Posts: 681  -  iTrader: (2)
Reviews: 3
rocktron pro g.a.p
So I picked up a 5150 combo, sounds great, although a little noisy. I was running around different used instrument shops yesterday, and found my 535q wah for $50 in great shape, and at another place found a rocktron pro g.a.p. Now, honestly I just picked it up thinking i'd use the built in hush, maybe some eq to get slight variations on the 5150 tone. I have yet to try it out, but after reading the online manual I'm not sure this is a way to go. How would the hookup work? I'm thinking the effects send on the amp would go to the input of the pro g.a.p and either the effects send or the amp output of the g.a.p back to the effects return of the 5150. I'll try experimenting with it a little bit this afternoon, but any advice on the subject would be appreciated.
Old 10-03-2007, 03:43 PM
velocity  is offline
Posts: 494  -  iTrader: (14)
Re: rocktron pro g.a.p
i am not too familiar with the 5150 stuff. but the pro gap rips for metal! you no like, you let me know...
Old 10-03-2007, 03:53 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
try it both ways and see what sound you like best. You might want to consider visiting thestompbox.net and see what other folks might be saying.
Congrats on the purchase!
Jimmy
Old 10-05-2007, 11:39 AM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
The Pro GAP is a preamp, and a nice sounding one FWIW. But, for a Hush, you should probably just get a plain Hush, pedal or rack unit.
Old 10-05-2007, 03:09 PM
Reviews: 3
Yeah, I didnt really know anything about it when I picked it up...I just saw it in a stack of stuff by the door at south austin music, figured I'd give it a try. fwiw, at low volumes, though the hush or agx didnt really do what I wanted it to do,(it did get rid of some noises with hand covering strings and not playing) it did make the sound a little more 'present' if you will even with gain at 0(clean). It sounded a little more focused... All knobes at 0 boost or cut, the sound wasn't as organic though.
Old 10-05-2007, 03:36 PM
bammbamm  is offline
I had the Pro G.A.P., I agree with what the others say.
Run your guitar into the Rocktron input, then run the out to the 5150 effects return port. I'm sure you'll have no problem moving it, should you decide you don't like it, but it has a lot of great tones.
Bamm
Old 04-24-2008, 11:25 PM
JxMxFxPx  is offline
Posts: 18  -  iTrader: (0)
I wanna buy a Pro GAP but can't find one.
They were all over the place last week......
FS: Rocktron Xpression and MIDIMATE (UK) AirGuitar Classified Ads: Guitars and Gear 1 09-03-2006 07:35 AM
FS: Rocktron Intellipitch (Intelligent Pitch Shifter) VERY RARE! revsharp777 Classified Ads: Guitars and Gear 2 06-09-2006 09:31 PM
Rocktron nick1 Gear and Equipment 1 03-05-2005 10:20 PM
Tc electronics Versus Rocktron Intelliflex ? not2secure4u Gear and Equipment 2 06-20-2004 03:22 PM
