IT wont hurt the amp at all. It'
s okay to go into a cab with higher impedence. IT is bad to go into a cab with too low an impedence.IF you went into a 4
ohm cabinet, you would have a problem for sure.
THe way it works is that if you go into a 16
ohm cab, your amp will have to work a little harder to to get to a specific volume as it would have to if oyu plugged into a 8ohm cab. It will work the tubes more but it wont damage the output transformer.
