Old 10-12-2009, 04:17 AM
keysofapollo  is offline
Posts: 3  -  iTrader: (0)
Question
Signal chain Separation/FX Loop HELP NEEDED!!!
So here are my pedals and a summary of what I want to do - I have a dual amp setup
Amps:
Mesa Tremoverb
JC-120
Pedals:
Compressor/Sustain
X2 EQ
Wah
Digitech Whammy
Whirlwind A/B Selector
X2 Distortion
Phaser
Delay
Flanger
pitch shifter
tape reverb
This is how I want to run it exactly if I can!
Amp 1: MESA
<comp/sust.-eq-wah-eq-whammy-a/b-phaser-delay-flanger-pitch shifter-tape reverb-mesa tremoverb>
and
Amp 2: JC-120
<comp/sust.-eq-wah-eq-whammy-a/b-distortion-distortion-JC-120/W FX LOOP SEND TO PHASER-DELAY-FLANGER-PITCH SHIFTER-TAPE REVERB-FX LOOP RETURN.
Basically what I want to do is run (ALL OF THESE PEDALS minus the 2 distortions) to the Mesa Boogie , but I also want to send an fx loop from the Roland JC-120 through the last 5 pedals starting with the phaser to the delay, flanger, pitch shifter, and tape delay.....
I would do them all before the a/b out in front of the amp, but for some reason on the Jazz Chorus these pedals boost the hell out of the signal noise......
If there is anyway to do this could you give me a detailed summary of it? I guess it is pretty easy if it can be done, I am just over-looking it maybe......
I don't know if I could add some other pedal, or whatever to get it done I will.........
Thanks much,
Joseph Cramer
WHAT'S YOUR SIGNAL-CHAIN LOOK LIKE? jemaholic Gear and Equipment 91 01-25-2010 07:13 PM
Signal Chain... chaos731 Gear and Equipment 20 08-12-2008 02:39 PM
BBE 462 in signal chain Draco Gear and Equipment 1 09-09-2006 09:37 PM
Rack signal chain question - splitting signal to tuner luther Gear and Equipment 4 12-14-2000 12:06 PM
