Old 11-07-2009, 10:28 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
something wrong with my 5:25
i own a mesa 5:25 combo, very good amp, not exactly the sound i'm looking for, but i'm not getting another amp for a long time so i use it.
anyway, for a long time, can't remember when, it's had this strange kind of ringing noise that happens when you play a loud note, like on the burn channel or if the clean channel is loud-ish. like if you strum an open chord on the clean channel, there will be this metallic ringing sound. it kind of sounds as if there's a loose screw vibrating against the speaker or something, but i don't think there is. it definitely sounds like some kind of vibration.
also, on the burn channel (highest gain channel) with gain around 70% and master volume on about 70% too, the sound is really horrible at low volumes. like, notes break up and crackle and stuff. i got it almost exactly 2 years ago and it gets used a lot and i was wondering if the tubes are starting to pack in.
this is my first tube amp and i'm not exactly in the know about all the specific of tubes. i looked at em today and they had a blue colouring to them at the back of the tubes. there's the normal amber kind of glow and then there's a blue-ish glow at the back of them which i understand can mean a few things, one of them being a tube breaking down.
i'm gonna take it in for a look but still, any info?
Old 11-07-2009, 11:38 AM
nato101010  is offline
Posts: 1,002  -  iTrader: (0)
Re: something wrong with my 5:25
This sounds like what my VOX did when I blew the speaker up in it. I'm wondering if you have done the same?
Old 11-07-2009, 12:01 PM
cornstar70  is offline
Posts: 171  -  iTrader: (2)
Blue tubes + microphonic, high pitched ringing sound means it's time to replace your tubes. Do this: tap the tubes while the amp is on and off standby. Use something hard like a pen or pencil and if you can replicate the microphonic sound, then it's definitely time to change them.
Old 11-07-2009, 02:38 PM
speedy mcfeely  is offline
Posts: 293  -  iTrader: (1)
Mesa has a 5 year warranty. First change tubes, then send back to Petaluma.
Old 11-07-2009, 04:49 PM
SonicProvocateur  is online
Posts: 1,104  -  iTrader: (0)
Images: 3
Reviews: 39
+1
Also go with cornstar70's recommendation of tapping the tubes to check for microphonics. This is a good indication of a tube crapping out. Worst case scenario is a leaking screen grid resistor on the power tube which could lead to an amp failure/blown tube, but since the Express line is EL84 powered, this is less likely. Change the tubes, and if it continues, send her back to Mike!
Old 11-07-2009, 10:49 PM
Homebake  is offline
would a broken/speaker be caused by playing the amp too hard or actual physical damage?
Old 11-08-2009, 03:41 AM
Images: 3
Reviews: 39
Your Mesa should not have blown a speaker from wattage alone, it doesn't have the power and Mesa designs them incredibly well to withstand the rigors of high power abuse. It would only come from some sort of physical damage like maybe taking a blow from putting the footswitch in the back or something, etc.
Old 11-08-2009, 05:29 AM
Homebake  is offline
true. i do stuff a lot of crap in the back of it.
Old 11-08-2009, 03:46 PM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
The 5:25's are meant to break up at lower volumes, especially if you use the 5wtt setting, nature of the beast. I also say to tap the tubes just to be sure. I would recommend trying the Mesa 5:50, it might be more along the lines of what you are looking for. Good luck.
~Bones
Old 11-09-2009, 07:56 AM
Homebake  is offline
~Bones
nah, i don't think this is meant to happen...
i played a mesa mark iv (?) combo amp the other day, i think it was like 100 watts. friekin' amazing, best tone of any amp i've ever played, unbelievable.
Old 11-09-2009, 01:37 PM
Images: 3
Reviews: 39
I use a Mark III blue stripe and have been a Mesa dealer in the past. I'm still thinking your problem is tubes. I had a friend that had a Blue Angel that had some sort of weird problem with his reverb circuitry that made similar sounds to what you were describing, but thats a much more rare occurance. Id still suggest swapping tubes first, then resorting to factory repair second. The guys at Mesa are the best in the business. Friendly and second to none on know-how.
Old 11-09-2009, 07:21 PM
shogun  is offline
Posts: 1,525  -  iTrader: (13)
*facepalm*
mesa has telephone support for a reason, and the amp is under warranty......
Old 11-10-2009, 06:56 AM
Homebake  is offline
Originally Posted by shogun View Post
*facepalm*
chill out man, i live in australia and there's nothing wrong with asking people for some opinions.
Old 11-10-2009, 08:06 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Absolutely, could be as simple as replacing tubes rather that calling support at $$ per minute!
Jim
5:25, combo, mesa, tubes
Everything you know about Everything is wrong! S-man Off-topic / Miscellaneous 9 05-11-2007 11:05 PM
What Am I doing wrong?? phil27 Tech: Setup, Repairs and Mods 3 03-27-2007 03:56 AM
is it wrong to own a JEM.... - so soon? darthpolster JEM and Universe Guitars 51 03-02-2006 12:27 PM
What's wrong here? Xavier 7 JEM and Universe Guitars 5 02-21-2005 04:15 PM
Is this wrong?? SatchVai69 JEM and Universe Guitars 15 06-28-2002 08:04 PM
