Old 08-23-2007, 12:24 AM
AngelOfDeath  is offline
Posts: 46  -  iTrader: (0)
Speaker cable?
Hi. I just bought a speaker cable. However, now that I'm looking at it more closely, it doesn't say unshielded. I'm afraid that I might fry my power amp if I picked the wrong one. Would this work? My plan is to do the Axe - Power Amp - Cab setup. The cable is a 25 feet 1/4 to 1/4 16 gauge LiveWire.
Just a little paranoid. Thanks a bunch.
Old 08-23-2007, 12:28 AM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Re: Speaker cable?
You have a 25 foot cable to go from the amp to the cab?
Old 08-23-2007, 12:32 AM
Re: Speaker cable?
yeah. it was on sale. I might return it for a shorter one. So is that cable fine or would it fry the amp?
Old 08-23-2007, 12:39 AM
Phishphood42  is offline
Posts: 540  -  iTrader: (0)
Re: Speaker cable?
If it says speaker cable on it, I think its ok to use as a speaker cable. But 25' is kind of ridiculous
Old 08-23-2007, 08:45 AM
yoyo1299  is offline
Posts: 637  -  iTrader: (0)
Re: Speaker cable?
ROFTL!! he DOES!! that's sooo funny. a 25 foot cable from the amp to the cab..... wow..
Old 08-23-2007, 08:50 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Smile
Re: Speaker cable?
Let's not go there yoyo
Jimmy
Old 08-23-2007, 09:00 AM
jb4674  is offline
Reviews: 6
Smile
Re: Speaker cable?
First of all, calm the hell down (I've always wanted to say that, )
I believe you're interpreting the term "shielding" a bit incorrectly. With a speaker cable, or any audio or video cable for that matter, to shield means to allow the cable in question to try to prevent it from picking up noise or interference from any source or signal that could potentially introduce noise to the cable in the form of hum or buzz.
Having a shielded cable or not would have no bearing whatsoever in you frying your amp. That's a completely different issue you're thinking about. You amp could get fried even if you had shielded speaker wires. The only way to minimize the chances of your amp getting fried is to connect it to a line conditioner/surge protector to protect it from voltage spikes and at the same time siolate noise coming from your electrical current.
This would be a good example of such thing:
Jimmy
P.S.: Return the cable and get a shorter one.
Old 08-23-2007, 10:34 AM
racerevlon  is offline
Posts: 932  -  iTrader: (1)
Reviews: 107
Re: Speaker cable?
What's wrong with long speaker cables? I have two low-gauge 25' cables that run from my rack setup (near me and my MIDI controller) to the other side of the stage where my stereo 4x12 sits. Is the concern signal attenuation or loss of fidelity?
Old 08-24-2007, 03:18 PM
CrossingStar  is offline
Posts: 1,046  -  iTrader: (1)
Re: Speaker cable?
One way to tell if it's a speaker cable is to plug it into your guitar then into a high gain type amp. If it buzzes and hums like crazy, it's a speaker cable.
Old 08-24-2007, 04:54 PM
bluealien  is offline
Posts: 959  -  iTrader: (0)
Re: Speaker cable?
I have a 25 ft cable for my cabs, because when I played out I use to place one of the cabs by the bassist and it widend my sound better for places with no PA...
Old 08-24-2007, 09:04 PM
Re: Speaker cable?
Jimmy
You're talking about a totally different topic. Guitar cables are shielded so outside noise doesn't get in. Speaker cables aren't shielded, because its unnecessary and they are carrying much more current than a guitar cable. Using an instrument cable as a speaker cable adds too much resistance, it can fry your power tubes and maybe even your OT
midi controller, power amp, rack setup, speaker cab
A guide to choosing tubes and cabinets! power freak Gear and Equipment 78 09-18-2011 11:35 PM
FS: New Hosa 14AWG speaker cable S420 Classified Ads: Guitars and Gear 1 04-02-2007 07:12 PM
Speaker or instrument cable? iPig Gear and Equipment 5 12-30-2006 09:59 PM
instrument vs. speaker cable Two hands31 Gear and Equipment 11 04-04-2005 08:10 PM
Have some Evidence Audio Cable info for you guys Paul Secondino Gear and Equipment 2 07-01-2004 05:46 AM
