Old 04-18-2008, 06:07 PM
Lifeofsobriety  is offline
Posts: 197  -  iTrader: (2)
Speaker Cable VS Instrument Cable
So this is kind of a noob question.
What is the difference between a speaker cable and an instrument cable.
Heres the issue:
Me and my buddy got together for a jam the other day. A few days later he realizes his speaker cable is missing. I look through my cables and alas there is an extra one there. The issue is the look exactly the same. A generic black cable with silver ends.... We arn't sure how to tell the difference. If we were to guess the wrong cable and use the instrument cable to go from his amp to his cab could it damage the amp? and is there any way to really tell the difference?
Thanks
Dan
Old 04-18-2008, 06:27 PM
adamcbest  is offline
Posts: 870  -  iTrader: (0)
Re: Speaker Cable VS Instrument Cable
the amp's output transformer will burn up!! big difference between the cables. never use an instrument cable as a speaker cable. although i think you can use a speaker cable as an instrument without harming anything.
Old 04-18-2008, 06:39 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
the easiest way to tell is to unscreww the cover of the connector for each cable so you can see the difference. At that point, label your friend's speaker cable so both of you know what it is.
Jimmy
Old 04-18-2008, 09:38 PM
Well we opened them and one of them is sealed... I compared the one that isn't sealed to one of my speaker cables and they look pretty similar... what should the main differences be...
I thought it would be an issue so thats why we didnt bother trying to guess.
Old 04-23-2008, 12:29 PM
Haha quick update
So we are definitely noobs.. the other day i took another look at these two cables.... and they are labled... in little white letters on the side of the cable haha thanks anyways
Old 04-23-2008, 04:54 PM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
a tip for the next time, or if you come across unlabeled cables...
PAY ATTENTION!
You'll have to unscrew the plug and look...
Instrument cables have braided wire around the outside of a single shielded wire
Speaker cables have two shielded wires and no braided wire.
It's not a great idea to substitute one for the other. That being said, an instrument cable will work 'ok' as a speaker cable in a moment of need, but a speaker cable will sound horrendous plugged into an instrument (especially a guitar)
Old 04-23-2008, 06:47 PM
So is that not right?
Thanks for the info on how to tell the difference though... that will be helpful.
Old 04-23-2008, 08:40 PM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
No, don't do this! An amp of high enough wattage will heat the instrument cable to the point where the insulation between hot and shield could physically melt, shorting the output of your amp, which, unless it has speaker fuse protection (and even with if you are unlucky), will short out your output transformer and blow it up! That's the LEAST that might go wrong - and rewinding/replacing transformers is about the most expensive repair you'll ever do to an amp!
The opposite way around (using a sspeaker cable as a guitar lead) will work, will not risk anything, but it will be an unshielded cable and you will get a lot more noise.
Old 04-24-2008, 01:00 AM
MadRyan  is offline
Posts: 246  -  iTrader: (3)
I use Canare speaker cable which is pretty big so it's easy to tell. I also use either Mogami or Canare instrument cable which tends to be on the small side, so again, easy to tell.
Old 04-24-2008, 07:34 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Just to give you the figures,
Power = Current^2 * Resistance
So for a 100 Watt amp into 8 Ohm cabs
100 = Current^2 * 8
12.5 = Current^2
sqrt(12.5) = Current
3.6 Amps = Current
Guitar Cables *WILL NOT* handle 3.6 Amps!
Aways use speaker cables for speakers!
If you make your own up, use cable that can handle the current (not 3 Amp cable)
Jim
(^2 means "squared")
Old 04-24-2008, 03:05 PM
My speaker cable is a beast too haha its like 5 times thicker than any of my other cables so i have never thought about this before.
It seemed like it would be a bad idea to use an instrument cable for an amp because of that very reason so I'm glad i didn't.
Thanks
david mccarroll, ohm cab, speaker cab
A guide to choosing tubes and cabinets! power freak Gear and Equipment 78 09-18-2011 11:35 PM
Should i use instrument or speaker cables to.... yoyo1299 Gear and Equipment 89 07-10-2007 05:47 PM
Speaker or instrument cable? iPig Gear and Equipment 5 12-30-2006 09:59 PM
instrument vs. speaker cable Two hands31 Gear and Equipment 11 04-04-2005 08:10 PM
Building my own instrument cable? - Made my own Triangle Gear and Equipment 1 10-13-2001 12:13 AM
