Re: speaker cables
Hey Paul, it doesn't really make a difference what kind of amp you have for requiring speaker cables. The point is that a guitar cable carries much less electrical current from guitar to amp than the speaker cable carries from amp to speaker. I'd recommend going with Mogami cables in general for your purposes, but Livewire stuff isn't bad either and it's a bit cheaper. The main thing is to get a cable that comes with a lifetime warranty, because most places will just give you a brand new cable if it breaks down on you when you have that warranty. There are lots of other more boutique quality cables but either brand I mentioned should suit your needs, I'd recommend 3-6 feet, just in case you ever have a situation where you can't sit the head right on top of the cab.
