Old 09-01-2009, 09:50 PM
IBNZ_RG  is offline
Posts: 543  -  iTrader: (0)
Reviews: 18
Question
Stereo and Mono Instrument Cables
Whats the difference between Stereo and Mono Instrument Cables? Will it effect the quality of my sound? Cause I have a mono Live Wire Soundhose cable is there any difference?
Old 09-02-2009, 08:23 AM
Cam-Vai  is offline
Posts: 313  -  iTrader: (0)
Reviews: 4
Re: Stereo and Mono Instrument Cables
stereo is really only useful if you have two inputs on you amp/ guitar
jerry garcia had two jacks on his guitar (http://www.nii.net/~obie1/deadcd/images/rosebuddet.jpg)
and that if you want delay or phaser going left right or something
cam
Old 09-02-2009, 11:04 AM
smooth55  is offline
Posts: 1,009  -  iTrader: (0)
Reviews: 59
+1, unless you're using a stereo signal, it won't be any different than a mono cable. That being said, for longer stereo signal cables, using balanced lines can make a difference in keeping noise out of the signal chain.
Old 09-03-2009, 05:01 AM
Cam-Vai  is offline
Reviews: 4
im really interested in getting a stereo delay setup!
how does the whole thing work? do i really need a slave/master head and all?
cable, mono, stereo
Wiring diagram for 4&16 ohm mono and 8 ohm stereo cab? Mr.WizardNeck Tech: Setup, Repairs and Mods 1 05-17-2008 09:25 AM
Behringer Ultrastack mono or stereo? ChrisB95678 Gear and Equipment 2 12-28-2003 01:05 PM
Cabinets - converting mono to stereo Mindgrip Gear and Equipment 8 01-07-2002 10:03 AM
Mono and stereo? Vaiworship Gear and Equipment 14 10-26-2001 10:59 AM
Stereo vs Mono - The Battle Begins RSVampire Gear and Equipment 31 05-29-2001 05:44 PM
