Old 02-01-2010, 03:25 AM
GuitarEvan07  is offline
Posts: 666  -  iTrader: (16)
Stupid Ohm/impedance question regarding setting up my half stack
I fell stupid for asking this, but I've recently been confused. Here are two pictures. What do I plug into what. Running one Marshall JVM210H head and one Marshall 1960a cab.
Thank you!
Old 02-01-2010, 03:57 AM
LonePhantom  is offline
Posts: 5,370  -  iTrader: (6)
Reviews: 98
Re: Stupid Ohm/impedance question regarding setting up my half stack
Do you want to run it mono or stereo? Mono is matching the 16 ohms with speaker cable. Stereo is plugging speaker cables in to each point with the switch to stereo.
Old 02-01-2010, 04:02 AM
Mono. So wait, on the head plugging it into the "2x16" or "1x16"?
then on the cab the 16 ohm input?
Old 02-01-2010, 04:44 AM
Weezel  is offline
Posts: 58  -  iTrader: (0)
Reviews: 24
Im not a professional at this or anything but from what I understand and use with my amps(I would like to think im right)
If your using one input, switch your cab to mono and plug your Wire into the 16ohm input on your AMP and connect it to the 16ohm input on your CAB
If you want to run it parallel using two wires, Switch your CAB to "stereo" and plug your wires into where it says 1x8-2x16ohm input on your AMP and connect them to your CAB
Make sense? I hope I do
Old 02-01-2010, 06:24 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Thumbs up
1) Switch the cab to mono (you don't have a stereo amp)
2) connect EITHER
a) 1 x 4 ohm output to 4 ohm input
b) 1 x 16 ohm output to 16 ohm input.
Jim
(didn't mean to add the thumbs up thingy!)
Old 02-01-2010, 05:21 PM
Thanks guys!
looking to buy a new half stack Overture2152 Gear and Equipment 5 10-11-2009 08:32 PM
Stupid question; setting up action on a lo-pro New Age Retro Hippie Tech: Setup, Repairs and Mods 1 06-15-2008 11:16 PM
WTT: Carvin Legacy Half Stack for Peavey Triple XXX half stack AKMG Classified Ads: Guitars and Gear 0 09-07-2006 11:01 PM
New Half Stack bonehead189 Gear and Equipment 18 01-07-2006 04:14 PM
Half stack Zeroleet Gear and Equipment 2 01-13-2004 11:04 AM
