Old 07-22-2007, 12:50 PM
carlos seo  is offline
Posts: 503  -  iTrader: (0)
Reviews: 5
Suggestion for a compressor
Hello all!
I'm looking for a compressor and I really like Boss CS-3. Is that the way to go, or you have other suggestions? If it helps, here's my current pedalboard.
Thanks!
Old 07-22-2007, 12:55 PM
shogun  is offline
Posts: 1,525  -  iTrader: (13)
Re: Suggestion for a compressor
yo dude.. i have a boss cs-3.. it all of a sudden wont work with a power source, I will try to get it fixed at my store, but i grabbed a visual sound - route 66 yesterday!!!! omgggg.. it definitely sounds a lot different then the boss.. it is a vintage style compressor, i definitely dont run it with as much compression as the boss.. i use the overdrive side of it has a gain boost on the dirty channel of my fender supersonic 112... so basically..
compressor always on
makes od's sound great on the clean
dirty channel is set to a low-mid gain (srv'ish)
i use another od to give me a half gained lead sound
and i use the od on the 66 for high gain.. sounds wicked..
i should ask, what style are you playing? the setup i am describing is for blues, jazz, fusion, country, pop, rock.. you can shred on it but it isnt a metal sound.. i have a diff setup for my metal band.
Old 07-22-2007, 02:15 PM
Holy Katana  is offline
Posts: 597  -  iTrader: (0)
^ How's the high-gain channel on the Super-Sonic?
Old 07-22-2007, 02:32 PM
S-O  is offline
Posts: 20  -  iTrader: (0)
Keeley compressor! The 4 knobber! It is compression orgasm in a box!
Edit: send in your t9 and ds-1, have Keeley mod em both. The Ds-1 ultra is to die for, and the T9 mods can send it back to vintage specs with audiophile parts, or the baked mod for more gain, I have the Flexi one and I heart it.
Old 07-22-2007, 02:39 PM
shogun  is offline
awsome, there is enough gain if u have moderate to high output pups.. but i like the sound better with gain 2 off, and gain 1 about half, then use a box to beef it up... it is very smooth, but with a good box, you really get that sharp pick attack and twang on the neck pickup.. it is perfect for country to classic rock.. wouldnt recommend for metal, maybe if you get the halfstack.. depends what kind of tone you are looking for.
Old 07-22-2007, 03:31 PM
Reviews: 5
shogun, I play many different styles, so I want something versatile.
S-O, my TS-9 has already been modified by myself, as well as my Crybaby. I think I'll do the the same to my DS-1 in the future.
What kind of mods does Keeley do to the compressor?
Thanks and regards,
Carlos
Old 07-22-2007, 03:43 PM
Salamander In The Sun  is offline
Posts: 859  -  iTrader: (4)
I used a Milkbox once, and it wasn't all that bad.
If you can afford it, buy one of Keeley's handmade compressors, though. They're very costly, but judging by Robert's other work, I'd say it's probably well worth the money.
Old 07-22-2007, 04:05 PM
Algiman  is online
Posts: 2,553  -  iTrader: (14)
Thanks and regards,
Carlos
It isn't a mod it is a complete pedal:
http://www.robertkeeley.com/product.php?id=8
Absolutely superb as well. I threw out the boss as soon as I tried the Keeley!I've had one for about 3 years now although I only use it subtly, but it does the job.
Old 07-22-2007, 05:01 PM
Reviews: 5
Hmm... $250, plus $30 Int'l shipping, plus $100 of Brazilian import taxes...$380 for a compressor... wow!
Too pricey for me.
I'll have to stick with 'retail' models...
Regards,
Carlos
Old 07-23-2007, 10:14 AM
Devo  is offline
Posts: 1,482  -  iTrader: (20)
You could build your own keeley/MXR/Ross clone for $80...
http://www.buildyourownclone.com/dynaross.html
or Try a BBE opto-stomp which is a softer compresser.. which Im currently using... its too soft for country but is good for evening things out...
http://www.bbesound.com/products/sto...tomp/index.asp
If I had the cash though I would like to try the keeley MXR/Ross clone but it should be no different from the BYOC mentioned above... Dont get me wrong I love my DS-1 SEM ultra mod!
so in summary... if you got the cash but not the time then go for a Keeley! otherwise join the revolution () and make you own!
Old 07-23-2007, 10:25 AM
Dazza1004  is offline
Posts: 265  -  iTrader: (4)
I've got the 2 knob keeley compressor and it one of only 2 or 3 pedals I really use. I love the fact it's so easy (I just leave both knobs at 12 o'clock) and it sounds great, no tone sucking at all.
Not cheap but excellent
Old 07-23-2007, 11:57 AM
Reviews: 5
So, the Boss compressor is not a good choice at all? What about MXR DynaComp?
I want some kind of Vai compression. Does it help to narrow down the choices?
Thanks and regards,
Carlos
Old 07-23-2007, 12:16 PM
Gudster  is offline
Posts: 441  -  iTrader: (0)
Thanks and regards,
Carlos
Its actually pretty decent out of the box IMO. But you can really improve the thing with this mod -
http://www.monteallums.com/Product_links.html#CS3Opto
Only $22 if you do it yourself. Read the reviews, it can be quite a pedal.
Old 07-23-2007, 01:33 PM
Reviews: 5
Wow, cool. Did you order this?
Cheers,
Carlos
Old 07-24-2007, 11:57 AM
chris101  is offline
Posts: 529  -  iTrader: (0)
The 'Build your own clone' Ross Compressor clone is almost an exact component match to the Keeley 2 knob compressor. I have both. the BYOC was a quarter of the price.
keeley mod, neck pickup
Needed some suggestion from u guys.... seongkeat J-Custom, USA Custom & Prestige Ibanez Guitars 19 07-21-2006 10:42 AM
Wah <-> compressor bobojem Gear and Equipment 1 09-29-2004 05:25 AM
Using a Software Compressor for semiprofessional studios. Nilsefix Recording Studio 2 11-13-2003 12:10 AM
which compressor: keeley or carl martin? SilverSurfer2 Gear and Equipment 5 03-08-2003 02:54 AM
Seeking guitar compressor recos bduersch Gear and Equipment 5 10-31-2002 03:09 PM
