Old 01-31-2009, 07:22 PM
kyates.yates  is offline
Posts: 54  -  iTrader: (0)
sustainiac question
hello i was just wondering, is it possible to install a single coil sustainiac in the middle position of a h-s-h style guitar. i am sure this question has been asked in an other thread but i didnt bother to look. thank you
Old 01-31-2009, 08:09 PM
Cathedral  is offline
Posts: 211  -  iTrader: (0)
Re: sustainiac question
Sustainers will only work best if installed in the neck position. I don't think you'll be able to get it to work very well in the middle position, if at all. You could try, but sustainers require major surgery on the guitar in order to be fitted, and it would be quite a shame to waste time/effort and a mass of wood to find it doesn't work in the middle position.
If you do get one, remember to turn it off when you stop playing. First day I had mine I left the sustainer switched on. Even though the amp is off, if you leave a cable plugged into the jack, the sustainer will stay on. Took me an hour to figure out what the faint OOOOOOOOO sound was coming from until I realised I left it on and the strings were still ringing.
Old 01-31-2009, 09:46 PM
AnDr3wYoN  is offline
Posts: 117  -  iTrader: (0)
If you look into the site they answer that question.
They say that if put in the middle the sustainer's magnetic field is to close to the Bridge Pickup or something like that.
They said that the sustainer would have a significantly less amount of power and won't sustain notes correctly. You might also get really loud feedback/squealing.
Old 02-01-2009, 06:21 AM
Devo  is offline
Posts: 1,482  -  iTrader: (20)
Hey there,
you need to move the sustainer as close to the middle of the string as possible to get the maximum effect. The closer it is to the bridge the harder it is for it to move the string.
The sustainiac system is tiny compared to the Fernandes one and can be installed without modification in most guitars. I put one in a JS without any extra routing.
Steve
Old 02-01-2009, 08:47 AM
skins345669  is offline
Posts: 835  -  iTrader: (0)
Basically, don't put it in the middle, put it in the bridge, and beware the routing task.
Old 02-01-2009, 12:27 PM
AxeHappy  is offline
Posts: 678  -  iTrader: (2)
No, you have to put it in the neck!
Old 02-01-2009, 06:53 PM
why did i even write that?
sustainiac
'Sustainiac' or 'Sustainer'?which one's Best? JTM45 Pickups & wiring 15 09-24-2009 09:49 PM
Sustainiac h100+101 Tech: Setup, Repairs and Mods 1 01-28-2008 02:57 PM
Fay PMC sustainiac . Zoot JEM and Universe Guitars 24 10-21-2007 07:30 PM
Sustainiac newbieguitarmaker Pickups & wiring 5 05-06-2007 10:43 PM
FS - MPX-100 and Sustainiac NIB tomizm Classified Ads: Guitars and Gear 2 07-28-2005 02:11 PM
