Gear and Equipment
The Best way to Raise the volume for Soloing?
Gear and Equipment
Page 1 of 3
04-01-2005, 07:21 AM
Kipperfetish
Posts: 54 - iTrader: (
What is the best way to raise the volume for soloing. I want to do this without changing the tone, or as little as possible. i have an effects loop so do i put a
volume pedal
in there are something?
Kipperfetish
Find all posts by Kipperfetish
04-01-2005, 08:55 AM
jem7vwh93
Posts: 40 - iTrader: (
Re: The Best way to Raise the volume for Soloing?
I just picked up a MXR ZW-44. Zak Wylde pedal. I use it to push my boogie from dirty to solo. What I like about it is that it doesn't affect my tone much - just makes it sing. I can't see getting Zak's sound with it though. Guess you need EMGs for that.
The volume pedal idea sounds interesting. Tell us how you make out.
jem7vwh93
Find all posts by jem7vwh93
04-01-2005, 11:31 AM
Stormcrow
Posts: 57 - iTrader: (
time machine booster pedal by Robert Keeley
there is a new George Lynch model
price is a little steep though around 300 bucks
here is a link
http://www.georgelynch.com/catalog/p...roducts_id=118
Stormcrow
Find all posts by Stormcrow
04-01-2005, 11:41 AM
Drew
Posts: 4,538 - iTrader: (
http://www.mesaboogie.com/Product_In...d_designs.html
built-in clean footswitchable solo boost across all channels - works like a charm.
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
04-01-2005, 12:21 PM
Rotti
Posts: 3,341 - iTrader: (
volume knob on your guitar.
Rotti
Visit Rotti's homepage!
Find all posts by Rotti
04-02-2005, 12:47 AM
red5
Posts: 2,639 - iTrader: (
Well on a
tube amp
, you will change the sound somewhat.
But may I suggest a Keeley Java Boost? It can be a treble booster, mid or full booster. I find as a treble booster it makes an excellent solo booster (at least for mildly overdriven tones) because it amplifies the high notes and really makes them scream.
red5
Find all posts by red5
04-02-2005, 01:32 AM
lyconxero
Posts: 1,469 - iTrader: (
Yet another reason why I love my Spider II. With the footcontroller that I use, I can just save my different settings. So I can quickly switch between normal dirty tone to my lead tone which is EXACTLY the same except it has the drive boost turned on (and up
) along with just a slight touch of delay and reverb. I can also adjust the delay with tap tempo right from the foot controller so if I want to change it mid-solo....no problem.
lyconxero
Find all posts by lyconxero
04-02-2005, 08:15 AM
BeastofLove
Posts: 795 - iTrader: (
Put an RC Booster at the end of your pedal chain in front of the amp. Turn the gain way down and the volume up to taste for your solo boost (on the pedal). This is a very transparent booster, unlike others that add thickness or the like. Works great for me.
Check 'em here:
http://www.prosoundcommunications.co...ter/index.html
-Ben
BeastofLove
Visit BeastofLove's homepage!
Find all posts by BeastofLove
04-02-2005, 11:35 AM
nick1
Posts: 211 - iTrader: (
Seymour Duncan
Pickup Booster.
It wont boost your gain at all just the volume.
nick1
Find all posts by nick1
04-02-2005, 12:36 PM
bpd111
Posts: 1,628 - iTrader: (
Voodoo Amps is working on clean boost, but I'm not sure if it's available yet. It'll retail for $195, but it's HAND WIRED!!
Keeley's Java Boost has already been mentioned but they have a Katana Clean Boost (same ball park price) which won't increase your gain -- the Java does. I don't know about the Keeley being hand wired (it probably is, since they build their pedals to order).
Both pedals should be true bypass, so it won't effect your tone too much otherwise.
bpd111
Find all posts by bpd111
04-02-2005, 01:44 PM
Whey
Posts: 234 - iTrader: (
Drew
-D
Thats what I use as well
09:38 PM
Whey
Visit Whey's homepage!
Find all posts by Whey
04-02-2005, 03:59 PM
red5
bpd111
Any kind of input boost will boost gain on a tube amp though. The transistor in the Java Boost does OD a little, but it still can be very clean. If you want to just boost the volume, put it around 12-1 oclock and it works nicely. Plus a little OD on solos even on a clean song usually is pretty cool.
red5
04-02-2005, 04:39 PM
BeastofLove
Just so there's no misconception- the RC Booster is really a clean booster; it can add some hair if you want, but it really isn't intended to overdrive anything much at all. I had a Greer Royal Fromage and you couldn't dial out the (slight) overdrie at all- with the RC you can. And unlike the Java or Fat Boosts, it doesn't alter your tone (which is neither good or bad- just depends on what you like). On the plus side, it does have Bass and Treble controls, so when you DO kick in the volume boost with it, you can up the treb and knock down the bass a tad so your solo cuts through a little better.
-Ben
BeastofLove
04-02-2005, 05:39 PM
bpd111
I haven't used either, just going by what I've read. The Java pedal is designed to boost gain. The Katana is not.
bpd111
04-03-2005, 12:40 PM
bammbamm
Posts: 4,134 - iTrader: (
I used to have an EQ set up just for boost.
If you're using a pedal setup, this is easily done, just add an EQ with say +3db on the level and then engage it during your solo and off again when you're back to rhythm. Another option if you're using rack gear (or any midi controllable system) is to add a preset with the same settings as your rhythm, but just add a tad more in the level department. When you need the boost, call up that preset and go back one, since you're not changing amp voices or effects, you won't get a noticeable drop in sound during the patch change.
Another option is to just add +3db in the 1k,2k, and maybe 2.5 Khz range for soloing, and roll back the freq's when your have completed the solo. Via midi this makes life so much easier.
Hope this helps,
Bamm
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
Page 1 of 3
marshall tsl
seymour duncan
tube amp
volume pedal
volume pedals
will a volume pedal work as an expression pedal?
volume pot is stuck
how-to clean volume knob
active pickups for soloing?
emg 81 what volume pots
HELP! Volume pot problem on my js1000btb.
Vaislittlefinger
09:26 PM
777DY wiring question(parallel/series) +volume question
mko
Pickups & wiring
08:06 AM
JCM2000 DSL100 volume swell problem
Joshka
Gear and Equipment
40
04-14-2004
06:49 AM
Volume Pedals
trouble311
Gear and Equipment
04:23 PM
Volume pedal for Solo boost
Dan D Mahnn
Gear and Equipment
02:03 PM
12:04 PM
