Old 08-18-2004, 04:07 PM
jwoods986  is offline
Posts: 378  -  iTrader: (5)
Thoughts on effects set-up
I've pretty much been a straight-into-the-amp kind of player (only effect I own is a Wah) but I was playing in a cover band and realized I needed some effects and a stage tuner. I picked up a Korg AX1500G last Nov. for $135. It's decent but last week I tried some of the effects manually and found that some just don't cut it. For example, I tried the "orange phaser" but could not get the early VH sound. I picked up a MXR 90 the next day, set it to the slowest speed, plugged it in, played the You Really Got Me solo, and BOOM had "the sound" I was looking for. Anyway, to make a long story short (too late), I'm going with pedals now. Here's what I bought or have coming in and wanted to know where I should put what in the chain (from research online, this is the order I was thinking once I have all the pedals): wah, DigiTech Whammy, MXR Phase90, Boss BF-2 Flanger, Boss CH-1 Chorus. I have a Mesa Single Recto head and use the amp's distortion. Second thing, should I run the chain "in front" of the amp or use the effects loop? Lastly, can I use the pedals and the Korg? I do like the reverbs, delays, and a couple presets from it (plus the tuner). Thanks!
Old 08-18-2004, 04:29 PM
guitarob  is offline
Posts: 130  -  iTrader: (0)
As a general rule of thumb, you want to have your modulating effects like chorus and flanger in your effects loop as well as any reverbs and delays. Your wah, whammy, and phase and any distortion effects should go in front of the amp.
Of course this is very general. Play around with different combinations and let your ears decide...Sometimes rules were meant to be broken!
Hope this helps...
digitech whammy, mxr phase
