Old 03-27-2001, 02:20 PM
cowcowcow  is offline
Posts: 289  -  iTrader: (0)
TS 9 to 808 mod kit - Do they worth?
Anyone tried?
Does it really sound better after mod?
Can they use on a TS9DX?
Where can I buy them except from Ebay?
Old 03-27-2001, 06:47 PM
Josh Blagg  is offline
Posts: 340  -  iTrader: (0)
TS 9 to 808 mod kit
I believe the all it requires is two resistor changes and the op-amp change if you have a ts9 reissue. *However, you have to make sure that the op-amp you switch in is exactly a JRC4558 (Japanese Radio Company, which has since changed its name). *Some people try to give you a similar Mouser 4558 op-amp chip that comes from Japan, but it is NOT exactly the same as the ones used in the original TS's. *
Most of the current TS line of pedals can be modified to have the exact circuitry of the 808, but only the TS9 reissue has the really simple fix. *If you aren't good with electronics, I wouldn't recommend doing yourself.
Old 03-28-2001, 01:41 PM
luther  is offline
Posts: 60  -  iTrader: (1)
TS 9 to 808 mod kit
My friend sent his off for the mod, *I left my TS-9 re-issue original. *We AB'd them after it came back. *The Mod was brighter and had slightly more gain.
In short, *it was not a big enough difference for me to want it.
Luther
Old 03-28-2001, 03:19 PM
alienx  is offline
Posts: 191  -  iTrader: (0)
TS 9 to 808 mod kit
Just get a Maxon 808 or a VoodooLab Sparkle Drive. They do it good and you save the soldering and maybe even screwing up the TS-9.
Old 03-29-2001, 10:39 AM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
TS 9 to 808 mod kit
I've done a few of them myself...bought kits on ebay and then found the parts on my own (very cheap). *I'm an electronics dummy and I was able to get the job done well with good directions. *The difference was less than I had expected, but worth doing if it doesn't cost you more than $20...I think it smooths out the tone *bit. *You can also swap another reisitor to add a bass boost, which really fattens the tone as well.
Greg * *
Old 03-29-2001, 10:43 AM
gkelm  is offline
TS 9 to 808 mod kit
Ooops, just read the rest of your post. *You can do the same mod to the ts9dx. *I have the parts and instructions...I suppose I could sell you a "kit" for $10 if you were interested.
Greg
